Best fitting blanket or shield #2199497
11/20/16 06:55 PM
11/20/16 06:55 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Who has the best fitting blanket or shield for a 727 trans ?
B&M shifter/cable . Deep pan . Dougs headers . In a 1968 b body .
Car is a daily driver
Thanks ,
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Best fitting blanket or shield [Re: tex013] #2199524
11/20/16 07:25 PM
11/20/16 07:25 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I used an RJS blanket with no problems. The straps were a little long and needed some trimming. I liked the old CSR shield for stock floor, fit well in a '63 Belvedere. I also had a TCI shield at one time but that one won't fit a stock floor.
Re: Best fitting blanket or shield [Re: tex013] #2199712
11/21/16 01:10 AM
11/21/16 01:10 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Lofgren makes a shorter blanket also, if he is still selling them.
Ultrabell is also an option.
Re: Best fitting blanket or shield [Re: tex013] #2199731
11/21/16 01:29 AM
11/21/16 01:29 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I don't think Chuck sells them anymore.... been forever since I've talked to him though.
Re: Best fitting blanket or shield [Re: tex013] #2199924
11/21/16 01:24 PM
11/21/16 01:24 PM
Medina, OH
dart440_72 Offline
dart440_72  Offline
Medina, OH
I bought one and took it to an automotive upholstery shop. They were able to shorten it. They weren't happy doing it because they broke a couple of needles doing it. We have a couple of leatherwork shops around as well. They said they can do it without any issues. They do a lot with horse saddles and really thick leather.
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
Re: Best fitting blanket or shield [Re: dart440_72] #2199926
11/21/16 01:27 PM
11/21/16 01:27 PM
an8sec70cuda Offline
As long as you don't need it to be SFI certified, then that's OK.
As far as I know Lofgren has been out of the blanket business for a while.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Best fitting blanket or shield [Re: ProSport] #2200003
11/21/16 03:57 PM
11/21/16 03:57 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
The Ultrabell only covers the converter, not the cast front drum and that is what hurts when it explodes and comes through the floor frown
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Best fitting blanket or shield [Re: tex013] #2200420
11/22/16 06:02 AM
11/22/16 06:02 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Thanks guys . Looks like a blanket will be the best /easiest option . Maybe dj safety or rjs .
Now if only the aussie peso wasnt diving
Tex
New best MPH 130.32
