Re: TIRED OF BEING SLOOOOOWWWWW.....................
[Re: mopar dave]
#2199443
11/20/16 04:56 PM
11/20/16 04:56 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
you know those turbos and prochargers are easier on parts than spray. I'm building my 511 with future procharger or turbo in mind. I hear people say that all the time......."oh, boosted power is easier on the motor than other power"......bullshizzit!!! 1000 hp is a 1000 hp and it doesn't matter to the parts how you get there
[Re: Monte_Smith]
#2199476
11/20/16 06:18 PM
11/20/16 06:18 PM
BradH
you know those turbos and prochargers are easier on parts than spray. I'm building my 511 with future procharger or turbo in mind. I hear people say that all the time......."oh, boosted power is easier on the motor than other power"......bullshizzit!!! 1000 hp is a 1000 hp and it doesn't matter to the parts how you get there I always figured the crank doesn't care how it ended up on the track, it just knows there was enough HP to push it out of the block. Maybe it hits the ground more softly if it comes outta a turbo motor than a nitrous motor?
[Re: BradH]
#2199498
11/20/16 06:55 PM
11/20/16 06:55 PM
Posts: 20,180 PA.
pittsburghracer
"Little"John
"Little"John
PA.
My thoughts on this thumper is more guy's respect you and your car at running 6.15 NA than will if it runs 5.80's on nitrous. I'm in the same boat running 6.004 NA and trust me I will get her in the 5's NA. I truelly believe your car helps promote your carb building business as it is right now. A little more work and tuning and you will be there
[Re: pittsburghracer]
#2199514
11/20/16 07:17 PM
11/20/16 07:17 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
My thoughts on this thumper is more guy's respect you and your car at running 6.15 NA than will if it runs 5.80's on nitrous. I'm in the same boat running 6.004 NA and trust me I will get her in the 5's NA. I truelly believe your car helps promote your carb building business as it is right now. A little more work and tuning and you will be there I hear what you guys are saying and respect those opinions so after my next outing I'll see how much weight removal/tuning I can do and make a decision...............
[Re: Thumperdart]
#2199543
11/20/16 08:02 PM
11/20/16 08:02 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I have a few nice plates I could sell you.
Brett Miller W9 cnc'd heads STR Chassis fabraction
#2199549
11/20/16 08:05 PM
11/20/16 08:05 PM
1967dartgt
Hilltown Pa
My thoughts on this thumper is more guy's respect you and your car at running 6.15 NA than will if it runs 5.80's on nitrous. I'm in the same boat running 6.004 NA and trust me I will get her in the 5's NA. I truelly believe your car helps promote your carb building business as it is right now. A little more work and tuning and you will be there That's only you and the rest of the purple shaft bridgade with those hang ups. I don't care how many poweradders you have.
[Re: 1967dartgt]
#2199570
11/20/16 08:48 PM
11/20/16 08:48 PM
Posts: 4,682 On the parachute mount
n20mstr
My thoughts on this thumper is more guy's respect you and your car at running 6.15 NA than will if it runs 5.80's on nitrous. I'm in the same boat running 6.004 NA and trust me I will get her in the 5's NA. I truelly believe your car helps promote your carb building business as it is right now. A little more work and tuning and you will be there That's only you and the rest of the purple shaft bridgade with those hang ups. I don't care how many poweradders you have. LMAO !
....BAD A$$ STREET CAR.....
[Re: Monte_Smith]
#2199577
11/20/16 09:18 PM
11/20/16 09:18 PM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
Why spray a car that already runs good?.........Simple answer is because it runs better. Just got back from the track helping a customer. 2900lb Mustang on 29.5s with a 370" small block. Ran some nice easy 5 teens How much to come help me do that?... on 26's
[Re: 1967dartgt]
#2199579
11/20/16 09:22 PM
11/20/16 09:22 PM
Thumperdart
State of confusion
I have a few nice plates I could sell you. Can't use a plate of any kind because of my dommy adapter............
[Re: SpareParts]
#2199584
11/20/16 09:41 PM
11/20/16 09:41 PM
n20mstr
Why spray a car that already runs good?.........Simple answer is because it runs better. Just got back from the track helping a customer. 2900lb Mustang on 29.5s with a 370" small block. Ran some nice easy 5 teens How much to come help me do that?... on 26's Thought you were past teens ?
[Re: Thumperdart]
#2199586
11/20/16 09:42 PM
11/20/16 09:42 PM
n20mstr
I have a few nice plates I could sell you. Can't use a plate of any kind because of my dommy adapter............ . Plate can go on top or under spacer/adapter
[Re: rickraw]
#2199588
11/20/16 09:43 PM
11/20/16 09:43 PM
n20mstr
Stay n/a. It's more impressive. Anyone can spray, not everyone can n/a. LMAO ! , Funny right there
[Re: 1967dartgt]
#2199590
11/20/16 09:49 PM
11/20/16 09:49 PM
Posts: 20,180 PA.
pittsburghracer
"Little"John
"Little"John
PA.
My thoughts on this thumper is more guy's respect you and your car at running 6.15 NA than will if it runs 5.80's on nitrous. I'm in the same boat running 6.004 NA and trust me I will get her in the 5's NA. I truelly believe your car helps promote your carb building business as it is right now. A little more work and tuning and you will be there That's only you and the rest of the purple shaft bridgade with those hang ups. I don't care how many poweradders you have. Put some teflon tape on those NOS fittings and you "NOS HEADS" will think clearer. Any monkey can run 5's in a big block Dart without a power adder. LOL. Especially one that has gone 6.15 already. Save the NOS for 4.90's-5.40's
[Re: Thumperdart]
#2199598
11/20/16 10:00 PM
11/20/16 10:00 PM
1967dartgt
Hilltown Pa
I have a few nice plates I could sell you. Can't use a plate of any kind because of my dommy adapter............ You know they bolt on top or bottom.
[Re: rickraw]
#2199601
11/20/16 10:06 PM
11/20/16 10:06 PM
1967dartgt
Hilltown Pa
Stay n/a. It's more impressive. Anyone can spray, not everyone can n/a. I guess that's why you have Monte Smith, Steve Johnson, Jeff Sprock, Kevin Neal, Paul K at Pkre, Nitro Dave all professional nitrous tuners because any body can do it. Lol only a NA guy says that.
