Re: Timing chain touching block 440 ?
[Re: 67R/T4speeder]
#2198606
11/18/16 07:00 PM
11/18/16 07:00 PM
RapidRobert
I couldn't tell much from the pic (I had the same prob with my hi tech Samsung mini camera till I engaged the flash function but at least it ain't ever caught on fire (yet), the picture looked OK on the camera screen for the split second it shows when snapped but then when later transferred to the computer it is dark. You are saying with the crank gear on by itself (no chain) that it is tilted, with it seated all the way in on the crank snout? EDIT I reread & you're talking about the cam potentially tilted and yes I can see the shiny left half. I dont have much to add but I would continue with a small straightedge to try & see see what surface is tilted. I would suspect the cam and or gears before the cam bore alignment. If the rest of the valvetrain is out/loose I would rotate the cam to 90 intervals & see if that tilts a straight edge on the front face of the cam itself. Keep us updated
[Re: 67R/T4speeder]
#2198626
11/18/16 08:10 PM
11/18/16 08:10 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Problem isn't the kiss at the casting flash circles, that's a common issue easily fixed.
The problem is the poor machining on the front cam journal where the gear is rubbing on the pass side ONLY. Does the cam turn freely in the block? If so then it's probably not a journal alignment issue.
[Re: Supercuda]
#2198628
11/18/16 08:21 PM
11/18/16 08:21 PM
Posts: 25,877 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Or the face of the front cam journal isn't machined square with the centerline of the cam.
[Re: John_Kunkel]
#2198644
11/18/16 09:15 PM
11/18/16 09:15 PM
Supercuda
About to go away
About to go away
up yours
That was my thinking as well.
[Re: 67R/T4speeder]
#2199467
11/20/16 06:09 PM
11/20/16 06:09 PM
Supercuda
About to go away
About to go away
up yours
With the face of that journal improperly machines a torrington setup will not work properly either.
It'll ride on the pass side just like the regular gear did.
