68 Charger floor pan replacement. #2198170
11/17/16 08:50 PM
11/17/16 08:50 PM
Texas
GTS440 Offline OP
GTS440  Offline OP
Texas
I am about to embark on a tremendous project. I am going to have to replace the floors from the firewall to the rear bumper on my 68 Charger. I have searched this forum but haven't found a detailed post on the subject as far as which panel first ect. I'm sure there is one I just haven't found it. Looks to me like I start at the firewall & work my way back? Would it be best to pull the engine & transmission first. Do I need to install any braces & I'm sure I need to take the tension off the torsion bars. Any guidance would be appreciated! Anybody ever weld them in with a tig to get that factory spot weld look? Thanks in advance for the help!!! GTS
Re: 68 Charger floor pan replacement. [Re: GTS440] #2199050
11/19/16 06:26 PM
11/19/16 06:26 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Pull the tail light panel to do the 1 piece trunk pan, mine was done on a rotissori.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: 68 Charger floor pan replacement. [Re: GTS440] #2199060
11/19/16 06:59 PM
11/19/16 06:59 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
Pull drive train it will only get in the way
Put on level ground and support it on stands
Start from front to rear
I only do a pan at a time
you shouldn't have to use extra bracing that way.
Re: 68 Charger floor pan replacement. [Re: GTS440] #2199276
11/20/16 07:07 AM
11/20/16 07:07 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Only link that might help that I can think of is to go here http://www.musclecarrestorations.com/gal...-005/?g2_page=5 and check for cars that have had the floors repaired or replace. As stated you're for sure going to need to remove the engine and transmission to do it right and safely.
Link to all of the Mopars they have done http://www.musclecarrestorations.com/gallery/main.php?g2_itemId=38868
floor removed
floor removed 2
floor removed 3
floor installed 4
There are LOTS more images and cars and it might be worth checking out the non-Mopar cars too?
http://www.musclecarrestorations.com/moparrestorations.html
MikeR
Re: 68 Charger floor pan replacement. [Re: A12] #2200441
11/22/16 10:41 AM
11/22/16 10:41 AM
Texas
GTS440 Offline OP
GTS440  Offline OP
Texas
Thanks guys! I'll check out those links & try to take lots of pics & maybe I can help the next guy. GTS
Re: 68 Charger floor pan replacement. [Re: GTS440] #2203627
11/27/16 11:58 PM
11/27/16 11:58 PM
Jackson, Mississippi
CornDogsCharger Offline
I've done this a couple times. On a '69 Charger 500, I replaced all of the floors from the firewall to the tail panel.... on a '69 GTX and a '70 Superbird, I did the same thing with the exception of the rear seat section area. The best advice that I can give is... just take your cutting out the old metal. It is easy to get in a hurry and cut something out that you did not intend to. Use a wire wheel to clean up the original spot welds so that you can clearly see where they all are. To remove/install the rear seat floor panel, you will also need to remove the large V-shaped brace assembly that is behind the seat frame. Take special care not to distort the brace so that you can reinstall it later. Another thing that will help, go ahead and weld the spare tire brace, the fuel tank brace, and the fuel tank strap braces to the the trunk floor before you weld the floor in place. It is a lot easier to do this out of the car than to try and crawl inside the trunk and weld. Hope this helps a little.
Justin
"CornDog"
1966 Dodge Charger
1968 Plymouth Satellite (Un-Restored "Survivor")
1969 Dodge Charger (W.B. General Lee)
1969 Dodge Charger (Future DMCL Clone)
1969 Dodge Super Bee, 383 4spd
