Page 25 of 85 1 2 23 24 25 26 27 84 85
Re: paint job on a budget!? [Re: 69chargeryeehaa] #21970
02/24/06 01:37 AM
02/24/06 01:37 AM
Richmond, Tx. (Houston)
GTSDave Offline
GTSDave  Offline
w as for your trim holes exit1965, you could get a copper block and weld in your trim holes. the weld does not stick to the copper, and the copper block helps disipate heat at the same time to avoid warpage.
That is what I did. See pics. I used a harbor freight magnet to hold the copper against the back of the weld. If you work alone this really helps. I then welded it up with my mig. Take your time and work slow to keep it from warping. See pics.
-Dave
Re: paint job on a budget!? [Re: GTSDave] #21971
02/24/06 01:38 AM
02/24/06 01:38 AM
GTSDave Offline
GTSDave  Offline
#2
Re: paint job on a budget!? [Re: GTSDave] #21972
02/24/06 01:38 AM
02/24/06 01:38 AM
GTSDave Offline
GTSDave  Offline
#3
-Dave
Re: paint job on a budget!? [Re: GTSDave] #21973
02/24/06 10:10 AM
02/24/06 10:10 AM
toronto canada
69chargeryeehaa Offline
toronto canada
nice job GTSdave
Re: paint job on a budget!? [Re: GTSDave] #21974
02/24/06 10:25 AM
02/24/06 10:25 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Can most of the holes be reached this way? e.g. the fenders cant be done like this can they, if they are on the car?
Re: paint job on a budget!? [Re: Exit1965] #21975
02/24/06 04:08 PM
02/24/06 04:08 PM
toronto canada
toronto canada
i would say all the holes can be done this way, if you go to a welding store or a good auto supply store they sell the copper block that is magnetic. granted you have to take off inner door pannels for example to get the block in behind the pannel but they are all accessable and can be done with this method. i've done it alot and it really works good.
Re: paint job on a budget!? [Re: 69chargeryeehaa] #21976
02/24/06 05:58 PM
02/24/06 05:58 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I think I'll try welding a chad in from the outside first, and if that doesn't work I'll tear off the door panels, take the tires off so I can attempt to get to the back of the fender, etc.
Back to this paint job thou, anyone else have any progress?
As for scratching, I can still scratch the cheap rustoleum with my thumbnail. The pro is a bit tougher.
Re: paint job on a budget!? [Re: 69chargeryeehaa] #21977
02/24/06 10:20 PM
02/24/06 10:20 PM
Va. Beach, Va
69superbee383 Offline
Va. Beach, Va
If you cant weld like me you can cut a piece of sheet metal and use panel bond adhesive to cover the hole then just use a skim of bondo over it. Works fine for a driver.
Also I was playing around with this way of painting and wondered if anyone has tried to use the same color Rustoleum in spray to do the jambs and engine compartment.
77 Macho Power Wagon LWB factory 440 70 Coronet 440 N code 3 speed
Re: paint job on a budget!? [Re: 69superbee383] #21978
02/24/06 10:22 PM
02/24/06 10:22 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I think thats what i plan on tryin
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: paint job on a budget!? [Re: 69superbee383] #21979
02/24/06 10:56 PM
02/24/06 10:56 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
My harbor freight hand punch arrived today. after replacing a cheap set screw with a real one, it works fine but is HARD to do. I have it mounted in a vise and use a pipe over the handle to pull down, this is making 3/16" punch from 16 gauge sheetmetal.
The chads it spits out fall into a cup I've put there, and all the chads will need is a few strikes with the hammer to flatten them out and they should work fine. I've already made about 10, so I have a ways to go with that thing. I hope it survives.
Re: paint job on a budget!? [Re: Exit1965] #21980
02/25/06 12:33 AM
02/25/06 12:33 AM
Topeka Kansas
K
ksj Online content
ksj  Online Content
K
Topeka Kansas
Going to go get paint tomorrow.87 SB truck with bad paint on the roof and hood only.Should start painting on Monday and have it done by the end of the week with before and after pics.Resale Red here we come.-Don
Re: paint job on a budget!? [Re: ksj] #21981
02/26/06 11:17 AM
02/26/06 11:17 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Re: paint job on a budget!? [Re: MattW] #21982
02/26/06 06:58 PM
02/26/06 06:58 PM
Anonymous OP
Anonymous OP
WOW! What a thread! I've read maybe 1/2 of it and feel compelled to ask my own question, hope it wasn't already asked and answered on a page I glossed over.
Anyway.....is this Rustoleum paint resistant to gasoline? I would hate to fill up and screw up the side of my car.
Also, what's with all the "deleted by Ira" replies? Hopefully not excessive censoring going on here
Re: paint job on a budget!? #21983
02/26/06 08:59 PM
02/26/06 08:59 PM
toronto canada
toronto canada
the deleted by ira posts was a guy that wanted to have a fight, things got ugly and he deleted the post.
i have a story about the resistance to gas: i was out for a cruise one day, in the sun, it was 38 dec celcus (100 deg F) and i stopped to buy gas, while i was filling gas on my orange beetle, the gas nozzel got stuck on full. so the tank filled and sprayed the whole front of the car when i pulled it out and threw it on the ground when it finally shut off. so there was my car in really hot sun on a hot day with the whole front of the car covered in gas. i complained to the owner and he gave me a free car wash, oh wow, i said i hope the paint will be ok. anyways there was absoultly to damage done by the gas on the whole front of my car, but it did eat the rubber on my running boards which i had to replace. also i painted a 71 kawasaki motor cycle gas tank about 15 yrs ago with black tremclad and i've spilt 15 years worth of gas on it and it still looks great. the paint is after all oil based. i've had gas stain single stage paint if you spill it and forget to whipe it in the sun.
Re: paint job on a budget!? [Re: 69chargeryeehaa] #21984
02/27/06 05:57 PM
02/27/06 05:57 PM
Anonymous OP
Anonymous OP
Hey guys,
I wondered over here from the samba (VW site). I'm building a fiberglass dune buggy which I'd like a cheap, durable, easily repairable paint job on, and this sure looks promising.
I tried the "Walmart" Rustoleum on a piece of scrap steel I got from work. I roughed the surface and did the 2 coats/wetsand process 3 times. The paint looked great and laid down nice, but like Exit1965 experienced, it didn't pass the fingernail test. I'm curious to see the results you guys get with the "industrial" kind. BTW, great thread!
Re: paint job on a budget!? #21985
02/27/06 06:15 PM
02/27/06 06:15 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I'm glad to know I'm not alone with the fingernail test, but sad to hear others are having the same issue (!).
I can still scratch the cheap stuff off fairly easily with my fingernail (digging in then pulling down), the industrial so far has been tougher but I can still do it.
There's probably still time for it to dry and harden more, but in any case I think it's unusual to have a sharp object dig in and scrape down, so I feel good (especially with the price) about painting a weekend cruiser car with it.
Re: paint job on a budget!? [Re: Exit1965] #21986
02/27/06 06:30 PM
02/27/06 06:30 PM
toronto canada
toronto canada
i can honestly say that the paint probally would have scratched off on my cars too. i noticed when i was assembling the 74 beetle about a week after painting that the paint would "dent", like when i was putting on the engine cover handle, and the handle was crooked, so i unbolted it and noticed that it left a dent, and the paint was really soft. you can barley see it now, i had to move the handle and rebolt it. but, i never tried to "scratch" it since i was not painting a test peice. i could see that it would scratch off eaisly in the first month or so, but now, honestly no matter how hard i try there is no way i could even put a hairline scratch in the paint with my nail. i honestly think that the rustoleum will dry the same as tremclad, i'd even be willing to put a wager! lol. it takes time for the paint to fully dry, and temperature plays a big role also, the colder, the longer it will take. even with modern paint jobs, your not supposed to wax even until like 3 months. and that stuff also remains soft. like when i shoot single stage, it also takes alot of time to dry.
Re: paint job on a budget!? [Re: 69chargeryeehaa] #21987
02/28/06 01:47 AM
02/28/06 01:47 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
On the "professional" rustoleum test area, just today I noticed that in one small area, the paint appears to be doing something very strange. Here is a picture. It's bubbling up or something here, and it super easy to scrape off. Any ideas what may be going on?
The "standard" rustoleum area can be seen in the 2nd picture, and it still looks good besides all the scratches I've put in it with various things, but mostly my fingernail. The final coat was applied 3 weeks ago to the day, and I can still scratch it easily. Either it will do something magical in the last week, or perhaps it will take a bit longer. I really hope it gets harder than it is. The weather has been cool and wet which I'm sure doesn't help.
Unless I can figure out the problem with the professional side (nothing is coming to mind..) I'll probably go with the standard, if it dries and hardens adequately.
Re: paint job on a budget!? #21988
02/28/06 02:32 AM
02/28/06 02:32 AM
Anonymous OP
Anonymous OP
I sprayed some seat brackets with some rustoleum primer, then gloss grey about 6 years ago... and took forever to harden where i couldnt scratch them(like weeks). I started to take the paint off and then ended up using different seats... I looked at the brackets this weekend, and the paint looks really good still, and hard. If you wait long enough it WILL harden.
Re: paint job on a budget!? [Re: Exit1965] #21989
02/28/06 10:05 AM
02/28/06 10:05 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I did some and think what caused the bubbling was probably heat from some drilling, welding and grinding I was doing a couple feet over. Somehow that area got too hot and bubbled up. At least that's what it looks like.
Glad to hear those seat brackets have rock solid paint now. Looks like waiting will do it from what everyone has said.
