Re: Full groove, 3/4 grove, or 1/2 groove main bearings.
[Re: MGC340]
#2196615
11/15/16 02:29 AM
11/15/16 02:29 AM
Posts: 4,457 Washington
madscientist
Washington
If you have factory oil, I always run full groove. You can't get the oil to the rods on time. Never seen one fail because it had a full groove.
[Re: MGC340]
#2196663
11/15/16 10:58 AM
11/15/16 10:58 AM
crabman173
crabman173
Never seen one fail because it did not have full groove--King used to make the HP series with a 3/4 groove--I always liked it but--they have dropped it and now only produce the half groove--they swear they have tested it every which way and can't see any advantage ---I have run every type in every combo you can imagine and have never been able to determine one was better than another--Full groove and loose you see it on the oil pressure gauge--other than that it is all speculation what is going on in there. I have asked my wife that when I die and am cremated--please toss a little of me down the throat of a badd azz engine running wide open so I can finally see what is going on in there-- I do lots of other brands engines that do not offer anything other than half groove--If there is plenty of clearance and no detonation etc they all come through with flying colors. The nightmare of a "spun" rod bearing keeps many folks awake --they Fear it in some crazy way that just does not line up with the fact that very very few folks ever experience that problem--some racers go an entire career without ever hurting an engine-- Irrational fear of a problem that is very rare --
[Re: MGC340]
#2196738
11/15/16 01:37 PM
11/15/16 01:37 PM
Posts: 4,209 New York
polyspheric
New York
One thing a groove definitely does is reduce local pressure at the bearing/journal interface.
Boffin Emeritus
[Re: polyspheric]
#2196822
11/15/16 04:21 PM
11/15/16 04:21 PM
madscientist
Washington
One thing a groove definitely does is reduce local pressure at the bearing/journal interface. That's true. The oiling system is constant flow, for the most part. Except to the rods and the rockers. They get timed oil. If you spin the guts out of them, and don't groove the cam so some oil gets to the rockers all the time, you can blue some adjusters and things like that. It's the same with the rods. They get timed oil. The problem is, Chrysler got the timing off. It's not usually an issue at lower RPM's. A full grooved bearing takes a timed oil system and makes it constant flow. You may not get full pressure to the rods all the time, but you get some oil out there, all the time.
[Re: madscientist]
#2197108
11/16/16 12:40 AM
11/16/16 12:40 AM
RapidRobert
If you spin the guts out of them, and don't groove the cam so some oil gets to the rockers all the time, you can blue some adjusters and things like that. They get timed oil. The problem is, Chrysler got the timing off. It's not usually an issue at lower RPM's. that is why I feed the rockers full time and redrill new holes in the adjuster and pushrod sides of the rocker and on thru to/into the shaft so the holes (.100") line up when the valve is closed so they get fed at that point and I solder shut the OE shaft holes on the adjuster side that are way off and also braze closed, the ones on top and the big access holes on the adjuster sides of the rockers (273 iron rockers)
[Re: RapidRobert]
#2197117
11/16/16 12:48 AM
11/16/16 12:48 AM
madscientist
Washington
If you spin the guts out of them, and don't groove the cam so some oil gets to the rockers all the time, you can blue some adjusters and things like that. They get timed oil. The problem is, Chrysler got the timing off. It's not usually an issue at lower RPM's. that is why I feed the rockers full time and redrill new holes in the adjuster and pushrod sides of the rocker and on thru to/into the shaft so the holes (.100") line up when the valve is closed so they get fed at that point and I solder shut the OE shaft holes on the adjuster side that are way off and also braze closed, the ones on top and the big access holes on the adjuster sides of the rockers (273 iron rockers) I just tap a ball of lead shot into the holes that don't line up.
[Re: ]
#2197143
11/16/16 01:19 AM
11/16/16 01:19 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
The nightmare of a "spun" rod bearing keeps many folks awake --they Fear it in some crazy way that just does not line up with the fact that very very few folks ever experience that problem--some racers go an entire career without ever hurting an engine-- Irrational fear of a problem that is very rare -- I'm not sure that's a Irrational Fear. IMO, that's the Most common failure, a Spun rod bearing. They spin from lack of crush/clearance or oil. My vote, Full groove for full oiling of the rod bearings. Not a Guarantee, but just extra insurance. 3/4 would be my next pick.
