Electrical experts please take a look. UPDATED
#2196119
11/14/16 12:26 PM
11/14/16 12:26 PM
Posts: 20,671 in a cattle trailer down by th...
Guitar Jones
I have a 92 D250 CTD 2WD with the 518 auto that I've converted to lockup. I'm using a Hobbs pressure switch off the governor pressure port to activate the ground circuit for the L/U solenoid. It is tied to the O/D ground circuit so I don't get L/U unless it's in O/D. But this method leaves a little to be desired because at certain speeds I get an annoying, in and out of L/U action. Normally it's not a problem but getting caught in traffic sometimes I can't get around it without slowing down. So what I'm looking to do is find a way to activate the circuit at a higher speed or pressure and have it stay engaged until it reaches a lower speed than the activated speed. Maybe a 5 MPH difference or something. I've not been able to find a switch like this in my internet searches so if anyone has any ideas I'm all ears. Thanks.
Re: Electrical experts please take a look
[Re: Guitar Jones]
#2196132
11/14/16 12:46 PM
11/14/16 12:46 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Might need two switched plumbed in a T, one for lower pressure, one for the higher pressure. Then a relay controlled by the switches. Use the ground from the high pressure switch to the relay coil ground, This will close the relay at the higher pressure setting. Wire the lower pressure ground to a one side of a set of NO contacts on the relay, jumper the other side on that pair of contacts to the relay coil ground, this will let the low pressure switch control the opening of the relay. Remember to wire the relay coil + to a switched 12V source.
On the second set of NO contacts on the relay run a ground to one side then run the other side to activate the circuit.
How this circuit will work is like this. As the pressure rises the low side switch will make, since it is going to a set of NO contacts on the relay the signal stops there as the relay is deenergized. Pressure continues to rise until the high side switch makes, this sends a ground to the coil negative, if you remembered to wire the coil + then the relay closes. With the relay closed you now have both sets of NO contacts closed. Your circuit will energize. The ground from the low side is now applied to the relay coil - as well. At this point both the high pressure and low pressure switches are applying a ground to the relay coil -, not a problem. As pressure drops the high pressure switch will open and remove it's ground from the relay coil -, but the low side ground will still be there thru the now closed contacts. Once pressure drops enough for the low pressure switch to open the ground will be removed from the relay coil - and the relay will open removing the ground from your circuit. At this point pressure will have to rise enough to close the high pressure switch and the cycle starts over.
Short of finding an adj hi/lo switch this is how I would do it.
[Re: Supercuda]
#2196211
11/14/16 03:11 PM
11/14/16 03:11 PM
Guitar Jones
[Re: Guitar Jones]
#2196233
11/14/16 03:49 PM
11/14/16 03:49 PM
RapidRobert
I still refer to your oiling mods regularly, Good job/good tech & much appreciated!
[Re: DaytonaTurbo]
#2196332
11/14/16 06:43 PM
11/14/16 06:43 PM
Guitar Jones
It's not for the O/D, it's for the L/U. I have it set to come in about 46 MPH now and I'd like it to turn off at about 40. Thanks for the help guys. More wiring fun in my future.
[Re: Guitar Jones]
#2196487
11/14/16 11:05 PM
11/14/16 11:05 PM
Posts: 4,757 Florida
BDW
I put 2 timers in so it doesn't search, Tranny has to be in OD 10 sec or LU won't happen. The 518 (46RH) is hydraulically controlled and uses 2 servos to enable the OD and LU. The 3-pin connector on the transmission supplies the control voltages. The center pin always has 12V power connected. The 2 outer pins are switched grounds. The front pin is the OD ground, the rear pin is the LU ground. The module works according to the following sequence. 1) The 12V toggle switch supplies voltage to the relays and transmission center pin. 2) When the hydraulic pressure trips (50mph/adjustable) the pressure switch, ground is supplied to the vacuum switch. When speed is below 50mph, hydraulic switch opens, disabling OD. 3) When there is enough vacuum, the vacuum switch closes, providing the OD relay ground. Under heavy acceleration, vacuum drops, opens switch, OD is disabled. 4) When OD relay has ground and 12V, it waits 10sec, then supplies 12V to the LU relay and ground to the transmission OD pin, enabling OD. 5) Now the LU relay has 12V, it's already grounded. It waits the 10 sec programmable delay then provides ground to the transmission LU pin. So lock up doesn't occur until OD has been enabled and on for 10sec. 6) The programmable delays for both relays fix the situation when speed is fluctuating around 50mph. This would normally cause the OD to kick on/off, the 10 sec (programmable) delay stops this from happening.
[Re: Guitar Jones]
#2196507
11/14/16 11:40 PM
11/14/16 11:40 PM
Supercuda
About to go away
About to go away
up yours
Good luck getting a vacuum switch to work on a diesel.
[Re: RapidRobert]
#2196685
11/15/16 11:45 AM
11/15/16 11:45 AM
Guitar Jones
I still refer to your oiling mods regularly, Good job/good tech & much appreciated! Thanks Robert.
[Re: Supercuda]
#2196795
11/15/16 03:28 PM
11/15/16 03:28 PM
Guitar Jones
Short of finding an adj hi/lo switch this is how I would do it. I've been trying to sketch out this circuit but I'm missing something. If one of you guys could draw this out for me I would really appreciate it. Maybe because the solenoids have 12 volts to them key on and the circuit needs to work on the ground side that I'm getting confused.
[Re: Guitar Jones]
#2196957
11/15/16 09:30 PM
11/15/16 09:30 PM
Supercuda
About to go away
About to go away
up yours
The solenoids weren't covered, just the pressure switches and the (you will need to add them) relays. I assumed the L/U and O/D solenoids always have keyed 12v to them and you switch the ground side to turn them on and off.
[Re: Supercuda]
#2197018
11/15/16 10:39 PM
11/15/16 10:39 PM
Guitar Jones
Ok, so I need a double pole single throw relay. That is where I was confused trying to do it with a single pole single throw.
[Re: Guitar Jones]
#2197078
11/16/16 12:14 AM
11/16/16 12:14 AM
Supercuda
About to go away
About to go away
up yours
If you want a single pole I can draw that up for you. I don't like switching the positive, it's noisier in an electrical system, but obviously the OEM's do it all the time. You will note that both the coil's switched 12V and the ground now goes thru a pressure switch, different ones though. Only way I could think of to use a single pole relay without getting real complicated and expensive. Not to mention automotive grade relays are cheap and easy to find with a single pole.
[Re: Supercuda]
#2197087
11/16/16 12:27 AM
11/16/16 12:27 AM
Guitar Jones
If you want a single pole I can draw that up for you But then doesn't the ground for L/U drop out when the high pressure switch opens?
[Re: Guitar Jones]
#2197102
11/16/16 12:37 AM
11/16/16 12:37 AM
Supercuda
About to go away
About to go away
up yours
In this circuit, the low pressure switch (S2) makes first, supplying switched 12V to the relay (RY2) coil, no lock up at this point. As pressure continues to rise the high pressure switch (S1) makes and supplies ground to the LU solenoid and the relay (RY2) coil, energizing the relay (RY2) and the L/U solenoid. As pressure drops the high pressure switch (S1) opens, but the relay is wired to self latch on the ground side, this is the jumper from the output of the relay contacts back to the relay coil -. The low pressure switch is still energized at this point keeping switched 12V on the relay coil + and the relay stays closed and L/U engaged. Once pressure drops off enough to open the low pressure switch it removes the switched 12V from the relay coil + and the relay opens, this will also open the ground latch. L/U is now de-energised. Once pressure starts rising the cycle starts again.
[Re: Supercuda]
#2197125
11/16/16 12:55 AM
11/16/16 12:55 AM
Guitar Jones
Ok, I get it now. Thanks a lot, I appreciate it.
[Re: DaytonaTurbo]
#2197133
11/16/16 01:10 AM
11/16/16 01:10 AM
Posts: 10,759 North Dakota
6PakBee
North Dakota
....This is why your home air compressor shuts off at 120psi and kicks on again at 90. If it didn't that thing would running darn near all the time. ...... DaytonaTurbo hit it with the air compressor example. If all you want is a deadband, then get a pressure switch with not only an adjustable setpoint but an adjustable deadband. Then you don't need all the space shuttle circuitry.
[Re: 6PakBee]
#2197256
11/16/16 10:55 AM
11/16/16 10:55 AM
Guitar Jones
....This is why your home air compressor shuts off at 120psi and kicks on again at 90. If it didn't that thing would running darn near all the time. ...... DaytonaTurbo hit it with the air compressor example. If all you want is a deadband, then get a pressure switch with not only an adjustable setpoint but an adjustable deadband. Then you don't need all the space shuttle circuitry. I know this but since there are a myriad of different switches or transducers like this I'm unable to determine exactly what I need for this application. So if you know what type of switch or transducer I need and where to get it that would be helpful. Ideally I need something that will turn on at about 65 PSI and turn off around 55-60 PSI.
[Re: BDW]
#2197416
11/16/16 05:13 PM
11/16/16 05:13 PM
Posts: 4,451 Michigan
MarkZ
Worthy
Worthy
I put 2 timers in so it doesn't search, Tranny has to be in OD 10 sec or LU won't happen. The 518 (46RH) is hydraulically controlled and uses 2 servos to enable the OD and LU. The 3-pin connector on the transmission supplies the control voltages. The center pin always has 12V power connected. The 2 outer pins are switched grounds. The front pin is the OD ground, the rear pin is the LU ground. The module works according to the following sequence. 1) The 12V toggle switch supplies voltage to the relays and transmission center pin. 2) When the hydraulic pressure trips (50mph/adjustable) the pressure switch, ground is supplied to the vacuum switch. When speed is below 50mph, hydraulic switch opens, disabling OD. 3) When there is enough vacuum, the vacuum switch closes, providing the OD relay ground. Under heavy acceleration, vacuum drops, opens switch, OD is disabled. 4) When OD relay has ground and 12V, it waits 10sec, then supplies 12V to the LU relay and ground to the transmission OD pin, enabling OD. 5) Now the LU relay has 12V, it's already grounded. It waits the 10 sec programmable delay then provides ground to the transmission LU pin. So lock up doesn't occur until OD has been enabled and on for 10sec. 6) The programmable delays for both relays fix the situation when speed is fluctuating around 50mph. This would normally cause the OD to kick on/off, the 10 sec (programmable) delay stops this from happening. This is a pretty slick setup, but wouldn't you run out of vacuum and fall out of OD after a certain speed? Adding another pressure switch that is rated higher that could lockout the vacuum switch could fix this.
[Re: Guitar Jones]
#2197615
11/16/16 11:12 PM
11/16/16 11:12 PM
Supercuda
About to go away
About to go away
up yours
He has a diesel, a vacuum switch is not relevant to a diesel.
