Re: black organosol hood paint
[Re: raybee]
#2196278
11/14/16 04:40 PM
11/14/16 04:40 PM
Posts: 2,096 New Mexico
JMCFAN
New Mexico
http://www.rogergibsonautorestoration.com/ORGP/ORGQ Organosol - authentic black textured finish for hoods, tail panels…………Qt $175.00 ***ONCE AGAIN AVAILABLE*** Pint $90.00
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
[Re: raybee]
#2196354
11/14/16 07:10 PM
11/14/16 07:10 PM
Posts: 18,157 Mass
DAYCLONA
Mass
HI,does anyone know where I can get this paint? It is DITZLER DDL-9355 Black Organosol 1970 for my roadrunner hood.Thanks for any help. If your going OEM, then by all means stick with the plan, if you want something more durable, easier to clean, and compatible with 99% of the topcoats out there, I'd recommend MarHyde Satin Black, with a little practice and spray gun technique you can create any texture/sheen you desire with this paint to replicate an organsol type finish here's the 70 hood paint specs should you need them... Mike
[Re: DAYCLONA]
#2196381
11/14/16 07:56 PM
11/14/16 07:56 PM
JMCFAN
New Mexico
HI,does anyone know where I can get this paint? It is DITZLER DDL-9355 Black Organosol 1970 for my roadrunner hood.Thanks for any help. If your going OEM, then by all means stick with the plan, if you want something more durable, easier to clean, and compatible with 99% of the topcoats out there, I'd recommend MarHyde Satin Black, with a little practice and spray gun technique you can create any texture/sheen you desire with this paint to replicate an organsol type finish here's the 70 hood paint specs should you need them... Mike Bummer.... 3M has ended production of Mar-Hyde® Black Satin™ Automotive Trim Coating 03812 quarts. We recommend Mar-Hyde® Black Satin™ Automotive Trim Coating - aerosol 03811 as a replacement.
[Re: JMCFAN]
#2196390
11/14/16 08:09 PM
11/14/16 08:09 PM
Posts: 18,157 Mass
DAYCLONA
Mass
HI,does anyone know where I can get this paint? It is DITZLER DDL-9355 Black Organosol 1970 for my roadrunner hood.Thanks for any help. If your going OEM, then by all means stick with the plan, if you want something more durable, easier to clean, and compatible with 99% of the topcoats out there, I'd recommend MarHyde Satin Black, with a little practice and spray gun technique you can create any texture/sheen you desire with this paint to replicate an organsol type finish here's the 70 hood paint specs should you need them... Mike Bummer.... 3M has ended production of Mar-Hyde® Black Satin™ Automotive Trim Coating 03812 quarts. We recommend Mar-Hyde® Black Satin™ Automotive Trim Coating - aerosol 03811 as a replacement. Somebody somewhere always has something still in stock...I just ran this all the way thru PayPal purchase, no indication it was not available from this supplier Mike
