Exhaust gasket question
#2194761
11/11/16 02:11 PM
11/11/16 02:11 PM
Posts: 1,001 Canada
Ghoste
Canada
Aluminum heads with cast iron manifolds, header gasket or oem style exhaust gasket? Or C), no difference and I've already thought too much about it.
I see a light at the end of the tunnel, and it's... ELECTROLUMINESCENT!
Re: Exhaust gasket question
[Re: Ghoste]
#2194775
11/11/16 02:24 PM
11/11/16 02:24 PM
Posts: 43,232 Bend,OR USA
Cab_Burge
I would probably use what I had on hand, if I had to buy some I would buy a decent set of header gaskets due to the expansion rate differences between cast iron and aluminum. You will need to retighten them several times until the fasteners take a permanent set
[Re: Cab_Burge]
#2194800
11/11/16 03:09 PM
11/11/16 03:09 PM
Posts: 1,001 Canada
Ghoste
Canada
To be honest, its the expansion rate part that was making me rethink the oem vs the typical header gasket. Thanks.
[Re: Cab_Burge]
#2195073
11/12/16 08:39 AM
11/12/16 08:39 AM
robertop
Cab Burge: if the fasteners have undergone a permanent set, then it's time to buy new ones.
[Re: ahy]
#2195418
11/12/16 10:41 PM
11/12/16 10:41 PM
Posts: 12 canada
BareAssBob
canada
I prefer no gasket with thick flange headers and AL heads. Just a thin coat of RTV. you can't be serious .
[Re: Ghoste]
#2195424
11/12/16 10:56 PM
11/12/16 10:56 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
A freshly machined aluminum exhaust flange mated to a cast iron manifold. I would expect any gasket to seal that up 100%.
[Re: BareAssBob]
#2195584
11/13/16 03:17 AM
11/13/16 03:17 AM
Posts: 20,662 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
I prefer no gasket with thick flange headers and AL heads. Just a thin coat of RTV. you can't be serious . High temp copper rtv is great for sealing stubborn header and collector gaskets. No reason why it wouldn't work on cast iron manifolds too. It doesn't take much - just a thin skim.
[Re: BareAssBob]
#2195627
11/13/16 09:50 AM
11/13/16 09:50 AM
Posts: 7,664 IN
ahy
IN
I prefer no gasket with thick flange headers and AL heads. Just a thin coat of RTV. you can't be serious . It has worked great. Also recommended by some header manufacturers. The factory generally did not use gaskets at all with manifolds. That way there is nothing to blow out.
[Re: robertop]
#2195650
11/13/16 11:27 AM
11/13/16 11:27 AM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
The point is... an exhaust bolt or nut will need to be re-tightened until it no longer gets loose. I don't use aluminum heads so I can't say what is used for a gasket. I use no gasket on exhaust manifolds.
I have mechanical Aptitude. I can screw up anything.
[Re: Neil]
#2195700
11/13/16 01:48 PM
11/13/16 01:48 PM
Posts: 298 mt. pleasant, PA
Diplomat440
mt. pleasant, PA
I prefer no gasket with thick flange headers and AL heads. Just a thin coat of RTV. you can't be serious . High temp copper rtv is great for sealing stubborn header and collector gaskets. No reason why it wouldn't work on cast iron manifolds too. It doesn't take much - just a thin skim. Works great. Its all Ive been using for years now, even on collector flanges.
[Re: Diplomat440]
#2195868
11/13/16 07:23 PM
11/13/16 07:23 PM
RapidRobert
Me too, I've used a thin coat of high temp RTV and or gaskets with a spray coat of Permatex "High Tack" 99MA the thin red spray in the purple can more for its' holding ability than for the gasket sealing (tho it does seal up) & had no issues either way. most header gaskets ain't cut to an exact match to the port so I trim it if too big or cut my own if too small
[Re: minivan]
#2196277
11/14/16 04:39 PM
11/14/16 04:39 PM
Posts: 2,592 None
71rm23
None
Not a problem since I installed remflex.... Same here. For fasteners, I installed these: http://www.stage8.com/
[Re: robertop]
#2197065
11/15/16 11:50 PM
11/15/16 11:50 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
The point of tightening a bolt is to put it in tension, which means stretching, without having a permanent set. If that has happened you have overtorqued it, and you cannot apply the correct torque to it anymore,and the bolt will eventually fail due to loosening or breaking. Ask any decent engine builder! You are correct that a bolt has to be under tension to hold. However it can lose tension by other means than exceeding the elastic limit. One of those is having an intermediary material that compresses or flows over time.
