Imperial Services Trans Conversion Cable Kit
#219465
02/09/09 08:42 PM
02/09/09 08:42 PM
Posts: 3 New Jersey
dmorgan
New Jersey
I am putting together a 65 Belvedere with a factory console and shifter. I am looking for opinions on the Imperial Services 1962-1965 Shifter Conversion Cable Kits. I see a lot of people recommending them, but I also heard some people had problems. I would like to hear from people who actually used a 66 and up 727 with the kit. Would you recommend it? Any problems? Email me at dmorgan@alumni.fdu.edu
Re: Imperial Services Trans Conversion Cable Kit
[Re: dmorgan]
#219467
02/12/09 10:35 AM
02/12/09 10:35 AM
Posts: 3,378 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
My dad and I installed this kit into his '65 coronet with '66 transmission last year.
Compared to the B&M ratchet shifter/cable setup I have in my Dart, my dad's conversion cable was very hard to adjust. You are supposed to be able to lift the cable out easily in any gear, meaning the shift lever is fully seated in any gear so there is no pressure on the cable. On my car with the B&M I can do that no problem.
On my dad's car though, we could not adjust it to be able to pull the cable out in any gear. We put it "in between" and it's close enough, the only problem is it has to be caressed into 3rd gear (we used a manual valve body). So far my dad has learned how to shift it into 3rd consistently, so it hasn't been much of a problem, but this is just a casual street car. I would probably be more annoyed with it than he is, but he manages with it as is.
I don't know what part of the system is to blame, but it could be the way the cable is twisted internally in order for the attachments at the shifter and transmission to fit. That's what my dad thinks it is.
I think if we had to do it again, I'd try to cobble my own "kit" together. It appeared to be a standard shifter cable with certain ends on it, a very lightweight spring to make it shift easier, and a standard shifter cable bracket that comes with universal shifters like B&M and Hurst. Perhaps the bracket is specially made for this transmission? I'm not sure, but it sure looked like the one that came with my B&M.
[Re: moparsquid]
#219469
02/11/12 10:43 AM
02/11/12 10:43 AM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
I recently installed the Imperial services cable conversion on my 65 coronet and It does not work well with the stock counsel shifter as advertised. I have tried to get a hold of them for advice on how to resolve my issues with the shifter. I can find no adjustment to change the way it works with the late model 727 without modifying the shifter itself. I would not recommend this company' services or components.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
[Re: BB65Barracuda]
#219471
02/12/12 10:22 AM
02/12/12 10:22 AM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
Does that really matter if you claim to be able to supply something that is not compatible? I just wanted to use my already built transmission from my 68 and was assured I could by Steve at Imperial. If I had the information to modify my shifter to work with there set up I would be satisfied. I can't even get a return email or phone call.
[Re: moparsquid]
#219473
02/12/12 02:31 PM
02/12/12 02:31 PM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
Nice info on the conversion and customer relations. MoparSquid, I know you didn't just fall off the hay truck and are mechanically minded, so I will use yours and the others info and not waste my money on the conversion. I will purchase something else. See you sometime at Signorellis or MATS.
Carl Kessel
[Re: Exit1965]
#219475
02/12/12 05:37 PM
02/12/12 05:37 PM
Posts: 25,866 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The trans lever supplied from Imperial Services is shorter than the B&M. The Imperial Services console shifter conversions that I've installed had interference problems with the lever pinch bolt contacting the case, other than that they worked OK.
[Re: John_Kunkel]
#219476
02/14/12 02:02 PM
02/14/12 02:02 PM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
John,
How did you adjust it to work with the shifter?Im all the way out and I have no more adjustment left. It would seem the cable is to long or the braket is incorrect.
[Re: BB65Barracuda]
#219477
02/14/12 03:16 PM
02/14/12 03:16 PM
Posts: 649 Davis, California, USA
MrBelvedere2
I'm very interested in this thread as well. I just installed an imperial services kit to keep my push buttons on my 56 plymouth with a 66 torqueflite. I installed it and it seems fine so far but I haven't been able to drive the car yet. When i had a helper push the buttons it looked like it wasn't moving the lever very far.
1965 Plymouth Belvedere II hardtop
[Re: CKessel]
#219479
02/15/12 02:40 AM
02/15/12 02:40 AM
Posts: 1,107 Spring Valley ,Ca.
moparsquid
Spring Valley ,Ca.
thanks ill be at the big three maybe well meet at the clubs space,seeya
[Re: moparsquid]
#219480
02/15/12 11:53 AM
02/15/12 11:53 AM
CKessel
Los Osos, Ca
Going to the 3 too! I'll be looking for some FMJ spindles and lower 73- b body arms.
Carl Kessel
[Re: CKessel]
#219481
02/29/12 06:59 PM
02/29/12 06:59 PM
Posts: 3 Frankenmuth, MI
sc68cuda
Frankenmuth, MI
9 out of 10 problems with the kits are related to the manual valve detent lever spring. Failure to use the spring supplied with the kit results in deflection of the pan rail bracket and leads to cable failure and potential transmission damage. No matter how much we stress the need for the correct spring(similar tension to the '62-65 spring), some "expert" decides it's not needed and uses a '66-later spring.
The 10th of ten problems involves the pan rail bracket - the bracket has two specific bends that position the cable housing properly so that the throws are correct. Imagine the cable coming to the transmission at a 90 degree angle - the distance the cable moves will be nowhere close to moving the manual valve lever the correct distance. Now imagine that the bracket gets bent to clear exhaust or cooling tubes - the precise alignment has been changed, and the throws are no longer correct.
Due to differences in the early and later transmissions, the conversion kit pan rail bracket will deflect slightly when the transmission is shifted to park - not a problem unless you're looking for one.
Building the short shift lever arm did require the pinch bolt nut to run very close to the case - it clears some cases but not all, due to variances in the machining relative to the case. We grind the edge of the nut for clearance and instruct the installer to check the clearance before driving the car. It's a simple matter to clearance the case if needed.
There is no real magic to this kit... we simply moved the '62-65 valve body shift geometry to the outside of the case. There are minor increases in effort due to the cable and linkage now being outside the transmission and not bathed in nice warm Dextron, but not enough to cause problems.
The biggest sources of trouble seem to be either well meaning transmission shops who don't want to use the wimpy spring (probably due to fear of transmission failure), or frustrated do-it-yourselfers who are more interested in seeing why the kit works than in driving the car. If the directions are followed and the kit is installed complete, without modification, it works.
There are literally hundreds of these kits out and about working just as they should. The problems we've had are nearly always a result of failure to follow the instructions or the installer adjusting the kit to fit an installation.
Steve
[Re: sc68cuda]
#219483
02/29/12 11:37 PM
02/29/12 11:37 PM
Exit1965
Rancho Cordova, CA
Steve
We installed the kit on my dad's car, followed directions, used the supplied parts, did not bend or modify anything, and it has the problem as described above which I wrote several years back.
We got it where it was "liveable" through adjustment and no, we did not contact you about it. It is very common for people to accept imperfections on parts if they just work "OK", and not contact the manufacturer. So you really have no idea whether there are hundreds of kits out there working "as they should". If it had major problems, we would have contacted you, but since it worked enough, we didn't.
It is not fair to say that for people that have the kit that does not work perfectly (as a factory or aftermarket shifter would, in my experience), either those people went renegade on the install and/or botched something up.
There are several people other than me who posted up there ^^ that the kit doesn't work right, no reason to think none of us was able to install this fairly simple kit correctly.
[Re: Exit1965]
#219484
03/01/12 02:13 AM
03/01/12 02:13 AM
moparsquid
Spring Valley ,Ca.
Steve
I too followed the instructions to the tee and when I contacted you(steve)was told several ways to correct any problems after many frustrating calls to the receptinest and getting nowhere i just changed it to a floor shift so i could at leest drive my car.I ve talked to many people who had many problems with Imperial Services, if the product didnt work it should have never been put out.now i have an expensive coffee table conversation piece.
