Manual Steering- Do you like it
#2194224
11/10/16 08:54 PM
11/10/16 08:54 PM
Posts: 337 Colorado
67plymouthman
Colorado
On my 67 Belvedere convertible w/340, both the power steering gearbox and pump need rebuilding. My friend has a very nice manual steering gearbox that he will give me. I know I will need the adapter and a different pulley-not a big deal.
Just curious for those using manual steering: do you like it or is it a pain in the butt? It's been several years since I have had a mopar with manual steering. The car is just a weekend cruiser.
Re: Manual Steering- Do you like it
[Re: 67plymouthman]
#2194246
11/10/16 09:27 PM
11/10/16 09:27 PM
RapidRobert
It's been several years since I have had a mopar with manual steering. The car is just a weekend cruiser. You'll be fine
[Re: topside]
#2194310
11/10/16 10:25 PM
11/10/16 10:25 PM
Posts: 16,147 Mesa, Arizona
dart4forte
Mesa, Arizona
Works ok in my big block Dart
Abe Lincoln
[Re: 67plymouthman]
#2194347
11/10/16 10:58 PM
11/10/16 10:58 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I drove a manual steering, so to speak, 64 300 for years. I say so called because the pump locked up and I ran it without a belt for years.
Which is more strenuous than a normal manual steering setup.
No problems.
But I don't spaghetti arms either.
My A body is manual steering, no problems but it is lighter than your B. Alignment spec and steering wheel sizes are different between the two types.
[Re: BareAssBob]
#2194380
11/10/16 11:28 PM
11/10/16 11:28 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
with a good tight box and a proper frontend alignment they steer great and way better feedback than power steering . This Having the alignment done right makes a big difference with a manual box. Hey welcome aboard fisherman Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2194403
11/10/16 11:53 PM
11/10/16 11:53 PM
Posts: 12 canada
BareAssBob
canada
with a good tight box and a proper frontend alignment they steer great and way better feedback than power steering . This Having the alignment done right makes a big difference with a manual box. Hey welcome aboard fisherman Gu s thanks Gus I was looking for a welcome wagon fourm but never found one .
[Re: 67plymouthman]
#2194458
11/11/16 01:00 AM
11/11/16 01:00 AM
Posts: 4,437 Omaha Nebraska
Brian_wo
Omaha Nebraska
Got any pictures of your car? I have a super rusty one out back that I am tearing apart and one in the garage that I am about to go full tilt on.
who is that guy?
[Re: 67plymouthman]
#2194743
11/11/16 01:48 PM
11/11/16 01:48 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Advantages: Simpler, no potential for leaks, saves weight, saves power.
I've had both in alot of cars and alot of it depends on how you drive your car. If you value quick steering skip the manual. My only complaint which is a big one, this ratio sucks.
[Re: Magnum]
#2194765
11/11/16 02:14 PM
11/11/16 02:14 PM
Posts: 1,001 Canada
Ghoste
Canada
Same opinion here. I've also had both and found it depends on what I used the car for.
I see a light at the end of the tunnel, and it's... ELECTROLUMINESCENT!
[Re: 67plymouthman]
#2194992
11/11/16 11:39 PM
11/11/16 11:39 PM
Brian_wo
Omaha Nebraska
I have pictures- how do you post them? During the post click file manager and pick your pictures.
who is that guy?
