Motorhome 727 rebuild ? #2191721
11/07/16 08:09 PM
11/07/16 08:09 PM
kerrville, tx
bigbertha72 Offline OP
kerrville, tx
Going have to rebuild the transmission on my 72 superior motorhome (m300 chassis), it got ran low on fluid and toasted the clutches. Its got the 413 with the 727 behind with the parking brake drum on the tailshaft.
What I'm wondering is what else should I upgrade while in there, I am leaning towards getting mrrandys billet servos and alto reds kit. Should I also go with a bolt in sprag or is that overkill? This is a "small" rv, only 20ft bumper to bumper and weights right at 10k.
Re: Motorhome 727 rebuild ? [Re: bigbertha72] #2191747
11/07/16 08:51 PM
11/07/16 08:51 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
I would call up CRT and see what he says, personally I would get a rebuild kit with the alto reds, the cheaper bolt in sprag (not the Super Sprag), a TF shift kit, a solid front band and possibly an HD band strut. If it doesn't have a deep pan it will also be a solid upgrade.
Re: Motorhome 727 rebuild ? [Re: bigbertha72] #2192264
11/08/16 05:09 PM
11/08/16 05:09 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
For your application I wouldn't do anything other than a good performance overhaul kit and a Transgo reprogramming kit. All that other stuff is a waste of money in a motorhome.
Re: Motorhome 727 rebuild ? [Re: bigbertha72] #2193432
11/09/16 08:46 PM
11/09/16 08:46 PM
kerrville, tx
kerrville, tx
thanks guys, ill call them up and see what they say.
Re: Motorhome 727 rebuild ? [Re: bigbertha72] #2193737
11/10/16 08:04 AM
11/10/16 08:04 AM
places
79powerwagon Offline
places
Sounds like a dedicated trans temp gauge will be a good idea, too. Mr Kunkel is a long-time mopar transmission expert here on Moparts and his advice typically is sound.
Re: Motorhome 727 rebuild ? [Re: 79powerwagon] #2194031
11/10/16 03:57 PM
11/10/16 03:57 PM
dogdays Offline
dogdays  Offline
I think the MH tranny is pretty HD as it sits.
If you're going to change the sprag use the Super Sprag. The bolt-in has the same weaknesses as the stocker.
Since sprag problems seem to go with rear ends blowing or driveshafts failing, is that going to happen to your motorhome?
R.
