Re: Washing greasy parts in the dishwasher: which soap/detergent
[Re: JimG]
#2191395
11/07/16 01:38 PM
11/07/16 01:38 PM
RapidRobert
JimmyG the JB weldmaster! You know I woulda thought that dish soap would be the ticket for that as they all tout their grease cutting ability in the ads tho the water getting in the harness would concern me so then I'd have to put em in the oven to dry em out!. what I would do is what you said, scrub em by hand then run em thru the machine
[Re: JimG]
#2191398
11/07/16 01:40 PM
11/07/16 01:40 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Please tell me you are kidding ? How did you plan to handle all the corrosion that will happen internally from having the wire soaking in water now too perhaps ? (Not like just hosing off the engine bay, where the water is going to run off the loom) I would have just used some liquid/spray degreaser and wiped down the loom with a rag. Orange hand cleaner and a rag works good for cleaning wiring too. Just take your time and do each wire at a time pretty much. Don't even want to think about what chemicals and residue might be left in the dish washer now if you ever washed dishes in it again too.
[Re: JimG]
#2191416
11/07/16 01:58 PM
11/07/16 01:58 PM
Posts: 3,922 Richmond, Indiana
19swinger70
Richmond, Indiana
In my crazy bachelor days, I used to wash parts in my dishwasher. I always de-greased first, then put into the washer. I ALWAYS used the dish washer soap. Using anything else will result in bad foam problems.
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: OzHemi]
#2191476
11/07/16 02:40 PM
11/07/16 02:40 PM
Posts: 75,012 U.S.S.A.
JohnRR
U.S.S.A.
Please tell me you are kidding ? How did you plan to handle all the corrosion that will happen internally from having the wire soaking in water now too perhaps ? Did you type that with a straight face ?
[Re: JohnRR]
#2191489
11/07/16 02:58 PM
11/07/16 02:58 PM
Posts: 531 Virginia
JimG
Virginia
Please tell me you are kidding ? How did you plan to handle all the corrosion that will happen internally from having the wire soaking in water now too perhaps ? Did you type that with a straight face ? Yeah, that one made me chuckle too.
[Re: JimG]
#2191538
11/07/16 03:46 PM
11/07/16 03:46 PM
Posts: 4,722 Moved to N.E. Tennessee
GomangoCuda
[Re: JimG]
#2191571
11/07/16 04:24 PM
11/07/16 04:24 PM
Posts: 25,806 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I think the PH level of ordinary dishwashing detergent limits its grease cutting ability. A cabinet washer detergent might work better but whatever you use it has to have anti-foaming agents AMHIK
[Re: JimG]
#2191577
11/07/16 04:28 PM
11/07/16 04:28 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Does your wife know you did that? A little off topic but it reminded me when I first went over to my neighbors house, the back deck was covered with dishes and pans for the dog and cats. Told the wife when I got home , DON"T EVER ACCEPT A DINNER INVITATION OVER THERE.
[Re: JimG]
#2192341
11/08/16 07:47 PM
11/08/16 07:47 PM
Posts: 6,562 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
I used Calgonite to flush out the mess an NTC Cummins oil cooler failure leaves behind in the cooling system. Flush the system twice one box per and milkshake all gone everything shiny new. Don't know if they still make it or not. If you aren't already single, there's a good chance you maybe soon. Kevin
