Inaccurate Fuel Gauge! #2191113
11/07/16 12:35 AM
11/07/16 12:35 AM
McMinnville, OR
TASummers Offline OP
McMinnville, OR
Hey guys,
Finally got my '64 Belvedere on the road (and strip) this summer. For the first few months, the gas gauge worked perfectly with a normal needle sweep. Then one day, a full tank began showing as "half tank" on the gauge - the needle straight down. From that "half tank" position, the needle seems to sweep normally to the left as I burn fuel. A true half-full tank of fuel shows the needle on "E", and an empty tank will place the needle to about the 8 o'clock position, far beyond and above the "E".
I have noticed that when filling the tank, the needle moves from the left to the right normally until it gets near the half tank mark - then the needle begins to jump and skip. The car has a new tank and sending unit.
Any ideas? And thanks ahead of time!
Ashley Summers
McMinnville, OR
Re: Inaccurate Fuel Gauge! [Re: TASummers] #2191142
11/07/16 01:05 AM
11/07/16 01:05 AM
LA & L.A.
MoparPosterChild Offline
LA & L.A.
Sending unit?
2018 Dodge DEMON #18
1970 Plymouth Duster 406" Stroker
1969 Charger 500" Stroker
1964 Dodge Polara 426 GEN III HEMI
1970 Plymouth Cuda Hellcrate Project car
1974 Dodge Ramcharger Project car
2017 Chrysler Pacifica Limited
2017 Ram 3500
2012 Dodge Caravan R/T
1972 Charger Mopar 392 HEMI Stolen
2008 Challenger SRT-8 Gone
2010 Challenger SRT-8 Gone
2006 Charger SRT-8 Gone
2007 Charger R/T Gone
Re: Inaccurate Fuel Gauge! [Re: TASummers] #2191152
11/07/16 01:20 AM
11/07/16 01:20 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Sending unit or ground. Check the metal piece that couples the gas tank outlet to the metal fuel line. May not be making good contact anymore.
Craig
Re: Inaccurate Fuel Gauge! [Re: denfireguy] #2191358
11/07/16 12:55 PM
11/07/16 12:55 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Float is leaky causing it to be heavy, or as previously mentioned,bad ground, or bad rheostat on sending unit.
beer
Re: Inaccurate Fuel Gauge! [Re: TJP] #2191627
11/07/16 05:42 PM
11/07/16 05:42 PM
I would confirm the ground is good with a jumper all the way up front to the batt neg post (get the gauge in the offending area & see if this ground wire changes things) but with it only acting up half the time it & appearing to be good the rest of the time it sure sounds as said like a rheostat winding prob (& sender needs to come out). First I would ohm it tho at several positions just to see what you get
