1979 dodge d50 project #2190372
11/05/16 10:52 PM
11/05/16 10:52 PM
Pennsylvania
W
Workhorse526 Offline OP
W
Pennsylvania
I have a 1979 Dodge d50 that is stripped. I have a mopar 340 engine. Looking to get a manual transmission for it. What do you suggest
Re: 1979 dodge d50 project [Re: Workhorse526] #2191536
11/07/16 03:37 PM
11/07/16 03:37 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
2 wd or 4x4? How stripped it the D50? What are your intentions with the truck when your done?
If you intend on drags trip or heavy street action with a 2wd, the 833 is the only smart choice, and its going to take some fabrication to get it there.
The stock D50 rear axle probably won't take the abuse either.
A 4x4 is going limit your choices a lot. Gene
Re: 1979 dodge d50 project [Re: poorboy] #2191604
11/07/16 05:10 PM
11/07/16 05:10 PM
dogdays Offline
dogdays  Offline
He asked the same question in the Q&A forum. Truck has a Dana 60 and the floor is cut out.
OP, IMHO you'll be better off removing the cab to work on the frame more easily. But before you do, position the engine as far back as you can as a 70/30 weight distribution isn't much fun to drive. You may even find the need to cut the firewall for clearance for the distributor, etc. And move the battery to below the bed on passenger side.
With the bed off, building the drivetrain, fuel and exhaust systems should be much easier. I'm guessing the Mitsubishi frame has plain crossmembers. You may need to move them around a bit. I'd suggest bolting them in rather than welding.
If you have the cash, a nice Tremec 5 or 6-speed would be my choice. The old standard A-833 is a choice, too. You're going to be building a floor, but you only have to do that once. The transmission you deal with at every drive.
Shoot, the A-500 auto OD trans would probably be a really good fit.
R.
I'd be hoping you're running 3.54s in that Dana.
