Bib Block ID
#2189708
11/04/16 10:09 PM
11/04/16 10:09 PM
Posts: 678 Marshall TX
Texas383
Marshall TX
I just got a '59 Coronet that has a 400 put in it.
On the pad under the distributor is 71 400 with 11 under that.
On the block skirt is 7R704371
Can anyone tell the year and what it came out of?
Thanx!
1969 Y2 Super Bee 1959 Coronet 4 dr Sedan
~ I intend to live forever...so far so good! ~
TO GOD BE THE GLORY!!
Re: Bib Block ID
[Re: Texas383]
#2189722
11/04/16 10:22 PM
11/04/16 10:22 PM
Texas383
Marshall TX
I will look for that next time I have it on the ramps
Re: Bib Block ID
[Re: dogdays]
#2189741
11/04/16 10:39 PM
11/04/16 10:39 PM
Posts: 43,286 Bend,OR USA
Cab_Burge
I have a 1976 late production 3/4 pickup truck 4 speed 400 C.I. motor that had a forged steel crank and thin balancer that was drilled a bunch for the external balancing by the factory according to the trucks original owner I had heard that the 400 stick shift motors all, pickup or cars, had forged steel cranks in them, this was the first one I've seen
Re: Bib Block ID
[Re: Texas383]
#2190096
11/05/16 03:27 PM
11/05/16 03:27 PM
Texas383
Marshall TX
Hopefully the bottom end is all good stuff from a truck and not a car. It runs great. I'll get it up on the ramps again and look at the casting numbers.
