Firing issues
#2189479
11/04/16 02:58 PM
11/04/16 02:58 PM
Posts: 678 Marshall TX
Texas383
Marshall TX
My 1969 Super Bee had been running great on all cylinders for years until the #3 and #6 plug wires burnt against header tubes.
To make a long story short I have installed new plug wire set, 8 plugs, distributor cap and rotor. But the #3 and #6 plugs still won't fire. I've put plug/wire that worked fine elsewhere and still no fire at 3 & 6. I put the two plugs and wires in different holes and they worked fine. I moved the distributor thinking maybe I had timing too advanced but still the same thing.
What the heck is going on here ?!?!?!?!
I need some help!!
1969 Y2 Super Bee 1959 Coronet 4 dr Sedan
~ I intend to live forever...so far so good! ~
TO GOD BE THE GLORY!!
Re: Firing issues
[Re: Texas383]
#2189493
11/04/16 03:24 PM
11/04/16 03:24 PM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
That or cylinders washed down.Try puttin a bit of oil i the holes after you make sure the firing order is correct.Rocky
Chrysler Firepower
Re: Firing issues
[Re: Texas383]
#2189700
11/04/16 10:02 PM
11/04/16 10:02 PM
Texas383
Marshall TX
I have checked firing order on the distributor cap 100 times(literally!!) : )
I've had the car 36 yrs and never seen anything like it.
Re: Firing issues
[Re: Texas383]
#2189711
11/04/16 10:13 PM
11/04/16 10:13 PM
Texas383
Marshall TX
When I pull the plug wires at the dist cap it arcs between wire and the contact. But the engine doesn't change RPMs or anything. So I know I'm getting fire to the wire. When I pull the other 6 wires the engine loses RPMs.
Could there be some sort of issue at the plug hole that would prevent the plug from grounding properly...?
Re: Firing issues
[Re: Texas383]
#2189717
11/04/16 10:19 PM
11/04/16 10:19 PM
therocks
Niles , Ohio
Maybe a bad cap on those 2.If the wires get fire to the plug it just may be the cap.The plug dosent need to be grounded.It would ground thru the threads or seat anyway unless you have ton of junk and then it should fire anyway.Rocky
Chrysler Firepower
Re: Firing issues
[Re: Texas383]
#2189718
11/04/16 10:21 PM
11/04/16 10:21 PM
RapidRobert
Could there be some sort of issue at the plug hole that would prevent the plug from grounding properly.? No, there is too much contact area. pull the plugs (all of em) & do a quick compression test on at least those (2) holes.
Re: Firing issues
[Re: RapidRobert]
#2189735
11/04/16 10:35 PM
11/04/16 10:35 PM
Challenger 1
Cincinnati, Ohio
Could there be some sort of issue at the plug hole that would prevent the plug from grounding properly.? No, there is too much contact area. pull the plugs (all of em) & do a quick compression test on at least those (2) holes. Exactly^^^^^^ You got at least 2 dead cylinders...sure the wires were fried yes, but I bet you got a couple dead cylinders. Sorry. Time for a rebuild.
Re: Firing issues
[Re: Texas383]
#2190093
11/05/16 03:25 PM
11/05/16 03:25 PM
Texas383
Marshall TX
It was running PERFECTLY up until the wires burnt. Now it shakes the whole car at idle or run up.
I will have to check the compression because all the other stuff concerning cap/rotor, pugs and wires are OK>
Re: Firing issues
[Re: Texas383]
#2190098
11/05/16 03:30 PM
11/05/16 03:30 PM
RapidRobert
It was running PERFECTLY up until the wires burnt. Now it shakes the whole car at idle or run up. (1) that is a puzzler (2) for sure more than 1 cyls ain't firing (or not in the right order) but agreed, you have checked em till you are blue in the face. EDIT I would suggest pulling back the plug boots & grounding em with a screwdriver as opposed to pulling the wire(s) off as coils don't like an open expecially on the secondary side tho people do it all the time but since Mr Murphy is paying you a visit on this deal we dont want to pi$$ him off anymore than he already is. For sure post what it ends up being
Re: Firing issues
[Re: Texas383]
#2190139
11/05/16 05:11 PM
11/05/16 05:11 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
You didn't swap the wires between cylinders?
Remember CCW rotation of the rotor, that's got me once.
Re: Firing issues
[Re: Texas383]
#2190147
11/05/16 05:26 PM
11/05/16 05:26 PM
Posts: 20,217 Park Forest, IL
slantzilla
Park Forest, IL
Just for funx swap the 3-6 wires in the cap. It won't cost anything. As said before, you may have them crossed.
I got bit once by a Mopar cap with the arrow on it. Wired it up by the arrow direction and it ran like crap. Arrow was in the wrong direction.
Re: Firing issues
[Re: Texas383]
#2190387
11/05/16 11:02 PM
11/05/16 11:02 PM
slantzilla
Park Forest, IL
Nope. I did cross the 5 and 7 on my 340 when I fired it. They are even numbered at the boots. ![fart fart](/ubbthreads/images/graemlins/custom/fart.gif)
Re: Firing issues
[Re: Texas383]
#2190647
11/06/16 01:01 PM
11/06/16 01:01 PM
therocks
Niles , Ohio
Did he ever say if he had fire to the plugs with them out?thats the first thing to check.My Imp once would not start when it had bad plugs and washed the cylinders.Let it dry some oil and new plugs and bingo.Fired right up.I doubt that a cam would go on two cylinders at once.
Chrysler Firepower
Re: Firing issues
[Re: therocks]
#2192158
11/08/16 01:44 PM
11/08/16 01:44 PM
Texas383
Marshall TX
I haven't tried to see if plug is firing with it out. But those two cylinders were dead with old plug or new plug, old wires or new wires. I replaced wires one at a time so I know there's not a misplacement of wires(AND I have CCW 1-8-4-3-6-5-7-2'd it to death.
This weekend I'm going to run a compression test and see if that is the problem. I'm still hoping and praying that it IS an oversight on my part and not washed cylinders!!
Re: Firing issues
[Re: Texas383]
#2192176
11/08/16 02:26 PM
11/08/16 02:26 PM
Challenger 1
Cincinnati, Ohio
Could there be some sort of issue at the plug hole that would prevent the plug from grounding properly...? This is a classic sign of dead clys, been there done it many times at work years ago. Every time I found very little or no compression. Used to just pull plug wires like you did to diagnosis how healthy a motor was without the expense of a compression test. Was never wrong when I did a compression test, it's the only thing it could be at this point. Sorry. 36 years is a long time, Mopar never meant for the motors to last that long.
