70 440 electronic ignition. The only thing I have tried so far is running a wire from the battery to the coil.
4 pin ECU/2 terminal "single" ballast conversion I am assuming. did it start when you jumped it? pull the yellow wire with tracer off of the "ign" terminal on the starter relay to disable the starter & have a helper hold the key to "start" & you under the hood see if the coil positive primary terminal and the blue/yellow wire at the ECU pentastar connector are hot (both should be & need to be)
