Driveshaft angle in tunnel
#2188791
11/03/16 03:40 PM
11/03/16 03:40 PM
Posts: 861 lancaster,california
johnnycuda
Hey guys, building a 69 Valiant, 408 with a A500 trans,8.75 rear, slant-6 car, using the TD Performance engine mount converison kit. I remember seeing somewhere about the angle of the driveshaft in the tunnel, not talking about pinion angle, but the angle from the tailshaft to the rear yoke. The article I saw said Mopar had the driveshaft at a angle in the tunnel to help with vibration, obviously the pinion is offset in the car at the rear, so is the driveshaft at a angle in the tunnel front to back. I haven't made the trans crossmember yet, using a T400 mount. The car had no motor/trans when I got it. Thanks in advance.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: Driveshaft angle in tunnel
[Re: Dave Hall]
#2188861
11/03/16 05:15 PM
11/03/16 05:15 PM
Posts: 11,645 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
If you are asking if the angle is side to side, looking from a plan(overhead) view, no. The whole shebang is moved to the passenger side. This. Straight line from front of crank to the pinion. The only reason for angle on the vertical axis is to allow for suspension movement. That doesn't mean that I haven't seen it run non-parallel to the C-L of the car due to a mis-match of engine and/or pinion centerline locations. And if it's not too extreme is probably not a huge problem on most cars. But don't build the car that way if it can be helped.
[Re: johnnycuda]
#2188889
11/03/16 06:06 PM
11/03/16 06:06 PM
johnnycuda
Thats what I thought, thanks. It has a stock width A-body 8.75 with the perches moved in 3", bought it that way, going to wait until I can get it on the lift to build the crossmember and make sure all is straight. The tailshaft is slightly towards the drivers side at the moment, but the mounts aren't tight and no crossmemeber of course.
[Re: johnnycuda]
#2189341
11/04/16 12:03 PM
11/04/16 12:03 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Johnny when I put the a500 in my Dart I centered it in the driveshaft tunnel. It was a fun set up. If you can get a empty case it makes set up a lot easier.
"Just a Bracket car dressed up like a streetcar"
[Re: johnnycuda]
#2189400
11/04/16 01:11 PM
11/04/16 01:11 PM
Posts: 10,013 Frostbitefalls MN (Rocky&Bullw...
gregsdart
It is not important for the transmission and differential to be perfectly in line In the horizontal. As long as the transmission and differential are parallel but offset, the drive shaft will be happy. I have an 8.8 Ford which is offset in a dart and there is no vibration at any speed. A drive shaft doesn't know or care which way it is offset. The U-joints compensate.
[Re: johnnycuda]
#2189444
11/04/16 02:09 PM
11/04/16 02:09 PM
johnnycuda
Thanks guys, once I take it to my buddy's shop and put it on the hoist, will be easier to align and finalize the mounts etc. and set pinion angle.
Should be a fun ride, 408 with RHS heads,.540/.556 cam, 2500 convertor in the A500 (low first gear) 3.73 rear, 275/60 drag radials, car should be light, manual steering/brakes, bench seat, was a slant-6 stripper.
[Re: johnnycuda]
#2189456
11/04/16 02:21 PM
11/04/16 02:21 PM
Just-a-dart
Glendora Ca.
Johnny you might want to get a little more rear gear 3.73 is a little flat in overdrive unless the converter is real tight.
[Re: johnnycuda]
#2189459
11/04/16 02:30 PM
11/04/16 02:30 PM
johnnycuda
Yep, I had A-1 build a 11", should be around 2500 stall, my buddy Darren from ProTrans has a similiar combo in his wife's Demon, so had them build the same convertor for mine. I figure the car should run high 11's on the motor, plan to drive to Fontana once in a while, run it and drive home...hopefully, lol. I was actually looking for 3.91's when I found the 3.73's at Woodley a year ago on a great deal, figured I'd try them and see how it does, swap out if needed.
