dragster pan ,oil drain #218834
02/09/09 03:03 PM
02/09/09 03:03 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
ive got a dragster milodon low pro. pan.i know i put 8 qts. of oil in it but can only get 4 out and that was slow.its the one with the trap door.when i filled it on the stand i put 8 qts.in and it wouldnt even go to the drain plud i had to suck it through.car ran fine good oil press throughout the run but WHAT A PAIN.is this weird or am i missing somthing?ive got the front 3 inches hirer than the drain.
Re: dragster pan ,oil drain [Re: bonefish] #218835
02/09/09 03:29 PM
02/09/09 03:29 PM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
Where is the drain plug in the pan? .... are you trying to drain the pan with the oil warm? ... getting the 4 quarts out .. how long does it take?
I have TWO diff projects going together using pans like this. A FED and a v drive boat. And the boat has a 12 quart pan.
Re: dragster pan ,oil drain [Re: dOOc] #218836
02/09/09 03:37 PM
02/09/09 03:37 PM
Mcallen, TX
SB449VALIANT Offline
Mcallen, TX
curios about what kind of susp. are you using with that pan? stock? tubular etc...? i also have 2 pans like that? one has never been out of the box, other is used...
Re: dragster pan ,oil drain [Re: SB449VALIANT] #218837
02/09/09 04:48 PM
02/09/09 04:48 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
well i hate to admitt this but i drained 4qts out into a gal container then had to attend to some other stuff and then a couple of days latter i decide to finish the job and forgot i already took 4 qts out.
Re: dragster pan ,oil drain [Re: SB449VALIANT] #218838
02/09/09 04:50 PM
02/09/09 04:50 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
its a chasis car with a rack.
Re: dragster pan ,oil drain [Re: bonefish] #218839
02/09/09 05:13 PM
02/09/09 05:13 PM
Mcallen, TX
Mcallen, TX
cool!!! any pics of the engine/front susp?
Re: dragster pan ,oil drain *DELETED* [Re: SB449VALIANT] #218840
02/09/09 05:51 PM
02/09/09 05:51 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
Post deleted by bonefish
Re: dragster pan ,oil drain [Re: bonefish] #218841
02/09/09 06:08 PM
02/09/09 06:08 PM
Mcallen, TX
Mcallen, TX
you put a notch in front of the pan right? iam also in a big problem, i need to cut my custom pan in order to make it fit around my k member,go and take a look of my pan in the 449 dyno post.. iam thinkng iam going to go the other way, do a dif. type/design of tubular k member.
