dragster pan ,oil drain #218834
02/09/09 03:03 PM
02/09/09 03:03 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
ive got a dragster milodon low pro. pan.i know i put 8 qts. of oil in it but can only get 4 out and that was slow.its the one with the trap door.when i filled it on the stand i put 8 qts.in and it wouldnt even go to the drain plud i had to suck it through.car ran fine good oil press throughout the run but WHAT A PAIN.is this weird or am i missing somthing?ive got the front 3 inches hirer than the drain.
Re: dragster pan ,oil drain [Re: bonefish] #218835
02/09/09 03:29 PM
02/09/09 03:29 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
Where is the drain plug in the pan? .... are you trying to drain the pan with the oil warm? ... getting the 4 quarts out .. how long does it take?
I have TWO diff projects going together using pans like this. A FED and a v drive boat. And the boat has a 12 quart pan.
Re: dragster pan ,oil drain [Re: dOc …] #218836
02/09/09 03:37 PM
02/09/09 03:37 PM
Mcallen, TX
SB449VALIANT Offline
Mcallen, TX
curios about what kind of susp. are you using with that pan? stock? tubular etc...? i also have 2 pans like that? one has never been out of the box, other is used...
Re: dragster pan ,oil drain [Re: SB449VALIANT] #218837
02/09/09 04:48 PM
02/09/09 04:48 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
well i hate to admitt this but i drained 4qts out into a gal container then had to attend to some other stuff and then a couple of days latter i decide to finish the job and forgot i already took 4 qts out.
Re: dragster pan ,oil drain [Re: SB449VALIANT] #218838
02/09/09 04:50 PM
02/09/09 04:50 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
its a chasis car with a rack.
Re: dragster pan ,oil drain [Re: bonefish] #218839
02/09/09 05:13 PM
02/09/09 05:13 PM
Mcallen, TX
Mcallen, TX
cool!!! any pics of the engine/front susp?
Re: dragster pan ,oil drain *DELETED* [Re: SB449VALIANT] #218840
02/09/09 05:51 PM
02/09/09 05:51 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
Post deleted by bonefish
Re: dragster pan ,oil drain [Re: bonefish] #218841
02/09/09 06:08 PM
02/09/09 06:08 PM
Mcallen, TX
Mcallen, TX
you put a notch in front of the pan right? iam also in a big problem, i need to cut my custom pan in order to make it fit around my k member,go and take a look of my pan in the 449 dyno post.. iam thinkng iam going to go the other way, do a dif. type/design of tubular k member.
