Manual master cylinder same as power brake master? #2182931
10/26/16 12:50 PM
10/26/16 12:50 PM
Boston, MA
johnnyd Offline OP
johnnyd  Offline OP
Boston, MA
1967 Chrysler Imperial with front disk brakes has a bad power booster. My son wants to use this car in the street class at our local drag track.
What's it take to convert power brakes to manual brakes? Is the master cylinder the same or is there a manual master cylinder that needs to be used instead? Is this even feasible or should he just get the booster rebuilt?
Re: Manual master cylinder same as power brake master? [Re: johnnyd] #2182937
10/26/16 12:56 PM
10/26/16 12:56 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
He can remove the booster , the difference in masters is drum brakes vs. disc and reservoir sizing for the front calipers.
Re: Manual master cylinder same as power brake master? [Re: johnnyd] #2182966
10/26/16 01:35 PM
10/26/16 01:35 PM
fury4speed Offline
fury4speed  Offline
Yes drum and disc are different.
Re: Manual master cylinder same as power brake master? [Re: johnnyd] #2182967
10/26/16 01:39 PM
10/26/16 01:39 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
He can use the power booster as a manual. He will have to watch his pedal ratio. The manual brake cars have the pushrod mounted higher up on the pedal. This gives more pedal power, at the expense of a greater distance of pedal travel. I'm not sure on a 67 Imperial, but some other mopars have a cantilever that lowers the pushrod from the manual position to the power position. If so, this can be removed and the pushrod mounted direct to correct the ratio.
Re: Manual master cylinder same as power brake master? [Re: JohnRR] #2182971
10/26/16 01:46 PM
10/26/16 01:46 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
He's going to have to sort out a pushrod and linkage for the brake pedal to the master cylinder. And get mounting studs for mounting the master to the firewall. There may be a different backing plate for manual vs booster mount for the firewall?
The linkage parts for a manual drum setup would probably work, might need to get an adjustable pushrod, which Dr Diff probably sells. And the rubber retainer to retain the pushrod in the MC piston.
A little backyard engineering involved, but not especially difficult.
Re: Manual master cylinder same as power brake master? [Re: johnnyd] #2182981
10/26/16 02:02 PM
10/26/16 02:02 PM
manual brakes need a MC with the machined circular groove in the rear piston "thimble" about halfway down for the snip of neoprene retainer on the manual brake pushrod to lock into. PB do not require this "groove" but can use a MC with this groove. all that is left is the bore dia and as mentioned possibly a pedal swap to change the ratio (if needed). if the MC has the groove & it is in good shape I would try it & if the pedal effort and or pedal travel is unacceptable then purchase a different one.
Re: Manual master cylinder same as power brake master? [Re: RapidRobert] #2183009
10/26/16 03:01 PM
10/26/16 03:01 PM
Crook County, ILL
Crook County, ILL
When I worked at Raybestos I noted that most if not all the disc brake mopar master cylinders from the 60s and 70s had the groove for the rubber pushrod retainer.
If the '67 master cylinder doesn't have it, they changed the master cylinder for disc C bodies in '69 to the same style used in B body hemis, that definitely would have the groove as there was a manual disc application of it used on taxis. And it's the same bore diameter 1-1/8".
Re: Manual master cylinder same as power brake master? [Re: johnnyd] #2183126
10/26/16 05:46 PM
10/26/16 05:46 PM
If I was you I would have the booster fixed up
How big is your Son and how strong are his leg muscles? How much does that car (Tank whistling) weigh work
I've owned and driven a bunch of the early large body Mopars including several Imperials, none of them would stop worth a hoot with the motor off when towing them work I was a lot younger then and I worked for the local telephone company climbing poles every day so my leg muscle where not weak, I weighed right at 200 lbs. at that time so my legs muscle where strong and stout shruggy
Be safe, fix the booster twocents
Re: Manual master cylinder same as power brake master? [Re: johnnyd] #2183145
10/26/16 06:08 PM
10/26/16 06:08 PM
WA
tman Offline
tman  Offline
WA
I totally agree getting the booster fixed. Imperial is a boulevard barge that is not easy to stop. Think of safety first.
Re: Manual master cylinder same as power brake master? [Re: johnnyd] #2183166
10/26/16 06:46 PM
10/26/16 06:46 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Bore size is different
Don't be the exception.
Re: Manual master cylinder same as power brake master? [Re: Supercuda] #2183588
10/27/16 07:03 AM
10/27/16 07:03 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Fix the booster.
The conversion is a lot of parts to come up with and make work.
I can tell ya that the booster failed on my 73 Imperial on the way to a strong 18.0 run at Union Grove. Wi... and I am lucky to be a in one piece... it is a bear to stop without the power working.
Re: Manual master cylinder same as power brake master? [Re: johnnyd] #2183599
10/27/16 09:01 AM
10/27/16 09:01 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Definitely fix/replace the booster, why would you want manual?
And sorry I have to ask, why race a barge like that? Is it for Halloween or something like that? That is the only way I could see taking a car like that to the race track.
Re: Manual master cylinder same as power brake master? [Re: johnnyd] #2188102
11/02/16 04:08 PM
11/02/16 04:08 PM
Boston, MA
johnnyd Offline OP
johnnyd  Offline OP
Boston, MA
He's strong enough to use manual brakes. 5'11" 230
Cab- don't forget vacuum boosted brakes don't push easily without vacuum because of their design. But a manual setup properly should be just fine. It will require more force than a vacuum set up but not nearly as much as a vacuum set up with the engine not running. Haven't weighed it but I imagine this boat is over 4k lbs.
The main reason I'm thinking of converting to manual is for drag racing in the future. If he ever builds any sort of engine with a cam and poor vacuum, then inconsistent brakes would become an issue.
I guess the simplest thing would be to just fix the stock setup that's there now. Won't have to worry about getting the right mounting bracket, pushrod, master cylinder etc. Brake lines to the MC look fine now so they could stay the same if he stays with the stock boosted setup but would have to be redone if the master cylinder was mounted directly to the firewall.
Thanks all!
Re: Manual master cylinder same as power brake master? [Re: johnnyd] #2188189
11/02/16 06:32 PM
11/02/16 06:32 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Since a boat like that didn't have manual brakes as an option you'd be stuck either trying to make something, or make something work.
A properly setup manual brake system isn't any harder to stop than a power setup. Pedal travel will be the only difference.
I've had plenty of power and non-power braked Mopars, both all drum and drum/disc setup and never noticed any difference in how the brakes "felt". Unlike Chevys which were very noticeable to me.
