Dodge truck doors and speakers #2188113
11/02/16 04:33 PM
11/02/16 04:33 PM
Canada
CrAzYMoPaRGuY Offline OP
Canada
I've got doors for a 1990 Dodge truck. Full height plastic door panels. They have built in speaker grills at the bottom and the doors have speaker cutouts.
What size speakers are usually used? The holes look like 6.5"x4.5" - I was wondering if anybody has installed 6"x9" speakers in their doors...?
Where else are good speaker locations? I would like to have four decent speakers that aren't an eye sore
Re: Dodge truck doors and speakers [Re: CrAzYMoPaRGuY] #2188157
11/02/16 05:40 PM
11/02/16 05:40 PM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
Usually a 6x9 in the doors
Re: Dodge truck doors and speakers [Re: CrAzYMoPaRGuY] #2188420
11/02/16 11:30 PM
11/02/16 11:30 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
I have 6x9 in the doors and a box behind the seats, sounds good.
Re: Dodge truck doors and speakers [Re: moparborn] #2188453
11/03/16 12:11 AM
11/03/16 12:11 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Sounds about right. My 90 w150 le had factory 6x9's in doors and some smaller longer, maybe 4x10's ? behind the seat, stuffed into cab corners above seat belt retractors.
Re: Dodge truck doors and speakers [Re: CrAzYMoPaRGuY] #2188757
11/03/16 02:46 PM
11/03/16 02:46 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Iirc, stock size is 5x7
Angry white pureblood male
Re: Dodge truck doors and speakers [Re: CrAzYMoPaRGuY] #2188909
11/03/16 06:52 PM
11/03/16 06:52 PM
Canada
Canada
Yeah I looked at the doors and it's apparent a 6x9 wont just bolt into the hole. I was told 6x9 but think maybe that was a guess now lol
Thanks!
CrAzYMoPaRGuY
Re: Dodge truck doors and speakers [Re: CrAzYMoPaRGuY] #2188993
11/03/16 09:18 PM
11/03/16 09:18 PM
Pennsylvania
P
polaris400cc Offline
P
Pennsylvania
6x9 for the convenience of availability and price, then front mount them so the factory door panel has no chance of interfering with the speakers and look 100% stock but sound much better. As far as rear speakers, I'm not much help as I have a ramcharger.
Re: Dodge truck doors and speakers [Re: CrAzYMoPaRGuY] #2189031
11/03/16 10:04 PM
11/03/16 10:04 PM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
Well, I've got a set of 6x9's with watershields from truck doors on the shelf. Maybe they shrunk the speakers in the 90 and up, don't know, haven't had the 93 doors open yet, mostly worked on 83/84. Also have a pair of the behind the seat speakers laying around, could measure them if you want.
Re: Dodge truck doors and speakers [Re: 1E2C] #2189162
11/04/16 12:47 AM
11/04/16 12:47 AM
chicagoland,usa
chicagoland,usa
Maybe ruderunner meant that the rears were 5x7's. The doors speakers were def. 6x9 in 1990 trucks, as they came with the plastic sheilds over the top side of them from the get go.
Re: Dodge truck doors and speakers [Re: CrAzYMoPaRGuY] #2189181
11/04/16 01:17 AM
11/04/16 01:17 AM
Canada
Canada
My speaker holes are never used, the opening in the door is 6.5"x4.5" so I got some trimming to do. My truck is a 1981 but the doors are from a 1990 I was told, maybe a different year but definitely newer doors.
Regular cab step side
CrAzYMoPaRGuY
Re: Dodge truck doors and speakers [Re: CrAzYMoPaRGuY] #2189236
11/04/16 06:36 AM
11/04/16 06:36 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Could be a 5x7 speaker..
You could check the crutchfield catalog for a replacement speaker.
Re: Dodge truck doors and speakers [Re: CrAzYMoPaRGuY] #2189359
11/04/16 12:22 PM
11/04/16 12:22 PM
Georgetown de usa
E
Eggman Offline
Eggman  Offline
E
Georgetown de usa
My 87 has 6x9's in the doors with an enclosure around them. They mount behind the holes in the door.
Re: Dodge truck doors and speakers [Re: CrAzYMoPaRGuY] #2190519
11/06/16 04:29 AM
11/06/16 04:29 AM
Canada
Canada
Well I tucked a couple Alpine Type R 6x9s in Boom Mat waterproof enclosures and they fit in the doors behind the stock panels. Doors had to be trimmed but it was an easy install.. Deck next.
Might look at a second set of speakers, but I don't want to see them.....
CrAzYMoPaRGuY
