Re: Brake guys - Manual brakes and Alum 7/8" bore MC qun
[Re: Supercuda]
#2176477
10/16/16 10:51 PM
10/16/16 10:51 PM
Posts: 7,664 IN
ahy
IN
Dr Diff can fix you up with a 15/16" master. Not sure about a 7/8". It sounds like a nice light weight brake setup. Also, per my understanding, those front calipers have smaller piston area vs stock and need quite a bit of brake line pressure. On a Cobra based setup in an E I needed a dual diaphragm 8" booster + 15/16" master to get full braking. http://www.doctordiff.com/
[Re: LAD 524]
#2176493
10/16/16 11:00 PM
10/16/16 11:00 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I don't think his setup is anywhere near stock and I am thinking not Mopar either, but brakes are brakes.
The sheet will show you what pressure changes might occur with a larger bore M/C.
[Re: ahy]
#2176494
10/16/16 11:00 PM
10/16/16 11:00 PM
Posts: 624 Deep DEEP SOUTH
LAD 524
Deep DEEP SOUTH
Dr Diff can fix you up with a 15/16" master. Not sure about a 7/8". It sounds like a nice light weight brake setup. Also, per my understanding, those front calipers have smaller piston area vs stock and need quite a bit of brake line pressure. On a Cobra based setup in an E I needed a dual diaphragm 8" booster + 15/16" master to get full braking. http://www.doctordiff.com/ Yep Cass fixed me up with the 15/16" MC originally, great guy ! FWIW - Piston area on the Dynapro is 2.76" on one side (1.38x2)
[Re: AndyF]
#2188091
11/02/16 03:47 PM
11/02/16 03:47 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Andy -- I was/am planning to make the swap to the 11.75: Cordoba discs, and had planned to use the lightweight Wilwood calipers WITH your caliper adapter brackets.. but I've been disappointed that those brackets were discontinued by you at least over the past year (or a little while longer than the past year). So, what you're saying is, in other words, to forget the Wilwood calipers (as well as the adapters.. if I could still find any out there)... and be better off with the stock cast iron calipers?... either sliders or pin types? I have 10.75 discs with pin-type calipers now. I want to avoid any larger rims such as 17-18s -- at this time for the next few years likely -- and keep using 15" rims (street/hwy crusing) and also to continue with my 16s for some HSAX/lapping sessions ans Hoosier AX SCCA Solo II events. Send me a PM if you want... T/Anks ahead... winter brake project in the works.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: AndyF]
#2189056
11/03/16 10:35 PM
11/03/16 10:35 PM
Posts: 1,491 Lethbridge, AB, Canada
dangina
The kit I was selling was using the largest piston size available from Wilwood. Those calipers had 1.75 inch pistons which worked out okay as long as the MC size and the rear piston size was reduced. It is a system so if you reduce the front piston size you also have to reduce the MC piston and the rear caliper (or drum) piston size.
I eventually gave up on the Wilwood stuff for a variety of reasons. A person can make it work but it isn't super high quality stuff so it is a lot of work and then in the end you don't have the best thing to show for it. The Brembo based kits are a better solution but most people don't want to pay that much money. I'm so happy I was able to get one of your brembo kits before they were discontinued, still one of my favorite upgrades!
