Re: 1964 newport issue
[Re: mb69]
#2188005
11/02/16 01:35 PM
11/02/16 01:35 PM
RapidRobert
OK my mind is blank right now. Now it won't start with the key won't even crank. Has new relay. (1) Oh that's the story of my life (2) see if the yellow wire at the starter relay is hot when a helper holds the key to "start". if it ain't hot then seperate the bulkhead & see if the back half is hot (key held to start). if it is hot at the SR then have him let off the key and you with a screwdriver jump from the large threaded batt stud on the SR to the brown wire terminal with the mini bolt that is next to it on the SR & see if it cranks & if so that tells you the starter the solenoid the battery and the large cables are up to snuff. if no crank holler & we'll continue on
[Re: mb69]
#2188054
11/02/16 03:01 PM
11/02/16 03:01 PM
Posts: 16,150 Mesa, Arizona
dart4forte
Mesa, Arizona
Bulkhead connections. Pull the connections and clean them with electrical cleaner. check the bulkhead connection to insure the pins line up and are tight.
Abe Lincoln
[Re: mb69]
#2195273
11/12/16 05:37 PM
11/12/16 05:37 PM
RapidRobert
Absolutely no rush bro (Here we have more time than money). pull the electrical connector off of the terminal on the side of the trans and ohm the male pin on the switch to the nearby trans case with it in park or neutral & there should be good continuity. then ground the connector/wire that you pulled off of it to the trans case then go back up front & see if it will crank. if it is the trans switch you can ground the male "grn" terminal back up at the starter relay to the SR metal case to bypass that safety feature for an easy fix if desired or take out the switch from the trans and reinstall it is the threads may have lost continuity to the case (not likely cuz there is alot of contact area) and or work with it on your bench with your meter and look in the trans to see if anything has come undone from the rooster comb. I am assuming this is a single wire connector, if it is a 3 wire then work with the middle pin and the middle wire. reportedly some replacement switches have the wrong length inside pin that contacts the rooster comb & wont work right so don't toss the old one if replaceing. EDIT you might wanna jack up the dr side to minimize fluid loss
[Re: RapidRobert]
#2195668
11/13/16 12:21 PM
11/13/16 12:21 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Push button right? I had a 64 New Yorker and it was push button. Long time ago and I don't recall just how it worked. I seem to think it was button in neutral and there was definitely a lever for park. Don't recall if start wire ran through the park lever or the button for neutral. I would think neutral should be it. Maybe something going on in that circuit?
I have mechanical Aptitude. I can screw up anything.
[Re: mb69]
#2195684
11/13/16 01:00 PM
11/13/16 01:00 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The park lever puts it in neutral as it goes into park, or it should anyway. Neutral switch is on the PB assembly, IIRC and there is an adjustment for it.
[Re: mb69]
#2195695
11/13/16 01:34 PM
11/13/16 01:34 PM
Supercuda
About to go away
About to go away
up yours
Got them backwards in my mind.
So, no adjustment on the neutral switch, assuming trans goes into N during park. In converted my 64 300 to automatic years ago, so the wife could drive it. But it's been many years ago.
[Re: Supercuda]
#2195850
11/13/16 06:47 PM
11/13/16 06:47 PM
bboogieart
Lost and Spaced
The park lever puts it in neutral as it goes into park, or it should anyway. Neutral switch is on the PB assembly, IIRC and there is an adjustment for it. So no neutral button at all? I got that one way off. It has been a few decades.
[Re: mb69]
#2195875
11/13/16 07:44 PM
11/13/16 07:44 PM
Supercuda
About to go away
About to go away
up yours
No, there is a N pushbutton as well, just that when you put the park lever into Park is also pushs in the N pushbutton, they are mechanically interlocked. P also engages N, but N does not engage P, if that makes sense.
[Re: mb69]
#2196090
11/14/16 11:09 AM
11/14/16 11:09 AM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
Supercuda is correct.On early ones the N button had the starter circuit on it.My 57 did as they ran it up to I think 59.I know 58 for sure.No park on them.Just a drum on trans as park brake.Some 62s supposedly came with park levers.My kids 300 did not as did the 62 Dodge we had years ago.Every 63 up we had did have park.
Chrysler Firepower
[Re: mb69]
#2196135
11/14/16 12:51 PM
11/14/16 12:51 PM
therocks
Niles , Ohio
Nope my kids 62 300 had aluminum trans and no park.Same with the 62 Dodge wagon we had years ago.Last iron trans was 61 with 8 bolt crank.Still have the trans from his 300 as he went to a CRT one for racing.Rocky
Chrysler Firepower
[Re: therocks]
#2196689
11/15/16 12:00 PM
11/15/16 12:00 PM
Posts: 19,470 north of coder
moparx
Nope my kids 62 300 had aluminum trans and no park.Same with the 62 Dodge wagon we had years ago.Last iron trans was 61 with 8 bolt crank.Still have the trans from his 300 as he went to a CRT one for racing.Rocky was the 62 wagon a dart wagon ? i remember pulling the trans from the newport wagon and it definitely was iron [and heavy !] and i was surprised to find an 8 bolt crank. this combo most likely was a transplant, because i bought it from a junk yard. when the car came in, it did not run, and the owner didn't know what was wrong with it. so with an 8 bolt crank, the crank end would be the [around] 1" longer stick out, no ? i don't own anything other than a '62 imperial FSM, and looking up the transmission section, you are correct in that transmission was aluminum with the e-brake assembly on the tailshaft. so i guess the question would be : exactly when did the park lever come to be, and in what body line being the first to have it ?
[Re: mb69]
#2196697
11/15/16 12:16 PM
11/15/16 12:16 PM
therocks
Niles , Ohio
IIRC it was a Polara Wagon.been decades since we had it.My kids friend had a 62 newport and it had no park.My other son had a 62 Imp.It also had no park lever.Might have been some made in late year that got the park.I do know the 63s and 64s we had did have park.
Chrysler Firepower
[Re: moparx]
#2196758
11/15/16 02:04 PM
11/15/16 02:04 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Nope my kids 62 300 had aluminum trans and no park.Same with the 62 Dodge wagon we had years ago.Last iron trans was 61 with 8 bolt crank.Still have the trans from his 300 as he went to a CRT one for racing.Rocky was the 62 wagon a dart wagon ? i remember pulling the trans from the newport wagon and it definitely was iron [and heavy !] and i was surprised to find an 8 bolt crank. this combo most likely was a transplant, because i bought it from a junk yard. when the car came in, it did not run, and the owner didn't know what was wrong with it. so with an 8 bolt crank, the crank end would be the [around] 1" longer stick out, no ? i don't own anything other than a '62 imperial FSM, and looking up the transmission section, you are correct in that transmission was aluminum with the e-brake assembly on the tailshaft. so i guess the question would be : exactly when did the park lever come to be, and in what body line being the first to have it ? 1964 Hewport,park lever,1962 Plymouth,park lever,1962 880 park lever,1962 Dart no lever,first park lever was 1962.No A-488 cast iron T/F after 1961 in passenger car.
