Re: any R5/P7 turbocharged motors out there? [Re: HOTMOPR] #2186738
10/31/16 02:47 PM
10/31/16 02:47 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
NASCAR P7 motors have huge flowing heads and are made to turn big rpm, and have thin rings.
Gotta think they wouldn't be the way to go with a turbo
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: any R5/P7 turbocharged motors out there? [Re: Georg] #2186827
10/31/16 04:53 PM
10/31/16 04:53 PM
Home
SRT6776 Offline
I hate internal combustion engines!
SRT6776  Offline
Home
What ever happened to the guy above with the red avenger? He always had fast stuff and used to post all over. ??
Re: any R5/P7 turbocharged motors out there? [Re: Georg] #2186924
10/31/16 07:46 PM
10/31/16 07:46 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
He is going to need new pistons for a turbo motor and at that time he can run any ring package he wants
Re: any R5/P7 turbocharged motors out there? [Re: scottb] #2187022
10/31/16 09:45 PM
10/31/16 09:45 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Been running a 40 pill in my R5 aluminum block. Cylinders have not moved.
Noah Strickland sprayed a 32 pill on his 358 drowning it with fuel and way overtimed. Only damage was pistons. Head gaskets didn't leak.
Re: any R5/P7 turbocharged motors out there? [Re: Leon441] #2187297
11/01/16 11:57 AM
11/01/16 11:57 AM
Vidor Texas
O
onyxba Offline
onyxba  Offline
O
Vidor Texas
The biggest problem is finding a cam core to run a turbo grind. Lsm is willing to build one but is pricey. Comp cams said there price was $3000.00 for 1 cam core are $3000.00 for 3 cores. Then I find ought that lsm makes comps custom cores. There are no cores that can go anything over 112 lobe separation. James at Bullitt cams said he is willing to do a custom core, you might talk to him if you are thinking of going this route. If you find anything different I would like to know. Iam talking about roller cams. Good luck.
Re: any R5/P7 turbocharged motors out there? [Re: Leon441] #2187320
11/01/16 12:39 PM
11/01/16 12:39 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Leon what have you run on the 40 pill?? That's cool!
