Re: is my 4 speed junk?
[Re: jcastle1]
#2185774
10/30/16 12:52 PM
10/30/16 12:52 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Check your fluid level. Low fluid will cause all kinds of noises. Check your shifter alignment. Whatever is wrong, doesn't mean the trans is toast. Fully rebuildable through Passon, Brewers and others.
[image][/image]
[Re: jcastle1]
#2185811
10/30/16 01:40 PM
10/30/16 01:40 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
I checked the fluid this morning it's full, is it possible that it was trying to get in 2 gears at the same time? That is possible, but the grinding noise has me concerned. A wild guess may be a main shaft bearing may be going.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: jcastle1]
#2185958
10/30/16 05:26 PM
10/30/16 05:26 PM
Posts: 43,301 Bend,OR USA
Cab_Burge
I would drain the fluid out of it through a cloth into a clean container and then run a small magnet through the cloth and old lube and go from there All transmissions , manuals and automatics make some metal, don't be overly alarmed with small particles, worry only about the big stuff
[Re: Twostick]
#2186360
10/31/16 12:22 AM
10/31/16 12:22 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
Clutch/release bearing?
Kevin My though as well. If it won't go easily into gear perhaps the clutch isn't getting it's .060 clearance when the petal is depressed.
[Re: Stanton]
#2186438
10/31/16 02:46 AM
10/31/16 02:46 AM
Cab_Burge
All the pre 1971 NP833 I've work on didn't have magnets on the drain plugs, we would JB weld them on the first time we had the drain plugs out. I've worked on three NP833 O.D. trannys recently and they all had that big flat round magnet your talking about I removed one from one that had a hole in the case from hitting something, I'll glue it back in there now that the case is welded up thanks for the update on why it was in there to start with
[Re: jcastle1]
#2186747
10/31/16 02:58 PM
10/31/16 02:58 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
tht's just it, it drives fine, goes into gear easily, but a few minutes after driving it aggressively it starts the noise, and I have to come to a stop, then it's fine again. I discovered this last night after taking it out for a drive again. Is it making the grinding noise when changing gears or when you are driving down the road and not changing gears ?
[Re: cgall]
#2187126
10/31/16 11:44 PM
10/31/16 11:44 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
If you have a cluster assembly end washer wearing out the cluster gears will start to off mesh with the main shaft . If it is really worn the cluster will move back and forth a lot causing grinding noise.
[Re: Stanton]
#2187674
11/01/16 09:44 PM
11/01/16 09:44 PM
rowin4
Years ago mine was making a racket and it was the input shaft bearing. to the previous post ... I've never seen thrust washers wear to that degree. I haven't either, but there's a video on YOU TUBE showing one that has. Or someone left it out upon assembly.
[Re: Stanton]
#2187983
11/02/16 01:00 PM
11/02/16 01:00 PM
JohnRR
Years ago mine was making a racket and it was the input shaft bearing. to the previous post ... I've never seen thrust washers wear to that degree. I had one in my 69 Bee that sounded like it was full of rocks running down the road, rear bearing was the problem. It made so much noise I could hardly hear a thing , once I rebuilt it I could hear the wiring under the dash shaking while the car was moving ...
[Re: jcastle1]
#2187986
11/02/16 01:04 PM
11/02/16 01:04 PM
JohnRR
I checked the fluid this morning it's full, is it possible that it was trying to get in 2 gears at the same time? only if your shifter is grossly out of adjustment , but then you would have a very hard time changing gears and that doesn't sound like the case. Has the trans been rebuilt ??? Cluster pin replaced , especially if it was run before with ATF ???
