Re: 2wd to 4wd conversion
[Re: 79beep]
#2187063
10/31/16 10:17 PM
10/31/16 10:17 PM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: 79beep]
#2188136
11/02/16 05:18 PM
11/02/16 05:18 PM
Posts: 440 Marysville, WA
77ProStreet
Marysville, WA
I did this on a 75 extra cab longbox. the only issue I had was getting the angle of the transfer-case correct. If you don't, you'll get a lot of bucking and chattering. Sorry! terrible pics! [img:left] [/img] [img:right] [/img] [img:right] [/img]
[Re: 79beep]
#2205399
11/30/16 07:03 PM
11/30/16 07:03 PM
Posts: 15,487 Florida
scratchnfotraction
we did a 77 club cab short bed that was 2x by cutting/removing the 2x kmember and all of the a-arm brackets. with a 4x4 k-frame and leafs/mounts/shackles/shock mounts we measured 2x then worked the frame and converted to 4x4.
looked factory stock exept for a few extra holes in frame here and there.
we used a 727 short shaft trans with a divorced xfer and frame cross member scabbed into the frame with custom shafts 6" lift 17/40/15 hawgs.
then I built a 79 RC with a 6" lift 17/40/15 hawgs and went with a 435granny 4 speed/married 203 xfer. now that rear shaft angle was a PITA
I lowerd the engine 2" ditching the rubber mounts and bolted right to the frame then lowerd the cross member 2" in the frame with tube spacer/bolts to level drivetrain out some and help the shaft angle. went with a double cv joint on both ends with a spline slip yoke in the middle.
