Green bearings and axle tube seals? #218705
02/09/09 01:10 PM
02/09/09 01:10 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Do you need to install axle tube seals when using green bearings? Thanks for your answers I know I should know this. Guess I'm having a senior moment. Jim
Re: Green bearings and axle tube seals? [Re: rt66jim] #218706
02/09/09 01:15 PM
02/09/09 01:15 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I used the inner seals w/my green bearing axle deal...........but, not sure why.
Re: Green bearings and axle tube seals? [Re: rt66jim] #218707
02/09/09 01:21 PM
02/09/09 01:21 PM
The green bearings are a sealed bearing so they don't need grease from the differential to be lubed, I use the inner seal when I can to help stop grease leaks onto the brakes.
Re: Green bearings and axle tube seals? [Re: Thumperdart] #218708
02/09/09 01:22 PM
02/09/09 01:22 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Many of the green bearing kits come with them, there must be a reason. I use them.
