over charging problems #2186457
10/31/16 04:33 AM
10/31/16 04:33 AM
TX
RiskyRickey Offline OP
TX
Had a problem with main wires at bulkhead losing connection , repaired wires that were getting hot & not making connection. Now amp meter goes to full charge above idle. Have ck.voltage at battery , shows 13.5 volts, but amp gage is high . Have changed voltage regular.73 Duster. Thanks in advance
Re: over charging problems [Re: RiskyRickey] #2186591
10/31/16 12:05 PM
10/31/16 12:05 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
make sure you have good ground on the VR. Check your battery . . . is it weak ?? That will make the charging system charge all the time. Normal voltage when running should be 13.5-14.4volts. . . . good luck
Re: over charging problems [Re: a12rag] #2186613
10/31/16 12:41 PM
10/31/16 12:41 PM
was it full fielding before the wiring work?. In the meantime pull the green wire off of its' alt male field terminal & see if the system stops charging. eng off, pull both field connectors off & see if either male field terminal has continuity to the alt case (should not). ohm the male field terminals together to each other & take a reading. New reg could potentially be bad. A depleted battery will make it overcharge. Do not run it like this more than just a few seconds to do each test as that high of pressure will wreak havoc on the system & have all lights and accessories off when doing the running tests.
Re: over charging problems [Re: RiskyRickey] #2186808
10/31/16 04:16 PM
10/31/16 04:16 PM
TX
TX
Did all the test above . All ck ok . Change battery cured problem thanks for all the help
