Page 19 of 85 1 2 17 18 19 20 21 84 85
Re: paint job on a budget!? [Re: Mobarge] #21850
02/13/06 02:04 AM
02/13/06 02:04 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
anyone use this paint method on a 600 hp car that wants to twist itself in half ? wonder if the paint will stick ?
Re: paint job on a budget!? [Re: 493_DART] #21851
02/13/06 02:06 AM
02/13/06 02:06 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Now at the 8th page for me im wayy confused on what to use and what not to use. I just want a good looking primer paint job. Not primer looking because ill screw that up Me & Paint do NOT get along
I returned that primer at lowes, im considering going and getting it again and just trying it before i just spray bomb the whole thing primer and have those little lines in it. (any method of sanding remove those lines btw?)
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: paint job on a budget!? [Re: GoodysGotaCuda] #21852
02/13/06 08:42 AM
02/13/06 08:42 AM
Q
Quicktree Offline
Quicktree  Offline
Q
go to ebay and look up auto paint it's cheap and you don't have to worry about if it will harden or not.
Re: paint job on a budget!? [Re: Quicktree] #21853
02/13/06 08:53 AM
02/13/06 08:53 AM
Anonymous OP
Anonymous OP
This guy is on my favorite sellers list.
http://stores.ebay.com/Auto-Paint
Re: paint job on a budget!? *DELETED* [Re: MoparforLife] #21854
02/13/06 09:47 AM
02/13/06 09:47 AM
St Charles MO
70Coronet500Vert Offline
St Charles MO
Post deleted by Ira
No matter how responsible he may seem, never give your gun to a monkey!
1970 Coronet Vert
1972 Charger
1974 Satellite Sebring Plus Sundance
2001 Ram 4x4
2002 Intrepid
2006 300C
Re: paint job on a budget!? [Re: Exit1965] #21855
02/13/06 10:35 AM
02/13/06 10:35 AM
toronto canada
69chargeryeehaa Offline
toronto canada
Topless & Blackwidow - great info. I guess the alternative would be to thin the cheap rustoleum with acetone or get the professional stuff and keep using mineral spirits.
Since my color, almond, comes in proffessional I'll try that and use the mineral spirits I already have.
69charger- does your tremclad mention anything about what to thin with, acetone, mineral spirits or?
it says on the can to thin and clean with varsol or mineral spirits, no mention of acetone.
Check This Out!! [Re: 69chargeryeehaa] #21856
02/13/06 11:12 AM
02/13/06 11:12 AM
Anonymous OP
Anonymous OP
Ok, how about this for the US version?
"Special polyamide-modified alkyd for maximum performance."
http://www.rustoleum.com/product.asp?frm_product_id=219&SBL=2
The Dunes Tan looks real close to my Rampage color.
Re: Check This Out!! #21857
02/13/06 11:21 AM
02/13/06 11:21 AM
Anonymous OP
Anonymous OP
Re: paint job on a budget!? [Re: Exit1965] #21858
02/13/06 11:58 AM
02/13/06 11:58 AM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
Valspar makes House Of Kolor paints? Neato...
They also make some powder coatings.
But that's not what we're talking about here. The stuff I saw at Lowe's only seemed to come in 29-oz cans, clear and pastel bases that NEEDED tinting. I can't find it on Lowe's web site, but it was called "Valspar Anti-Rust Oil Based Enamel". OK, upon Googling, I found this... Looks like they have an industrial line that comes in "many colors" in gallon quantities. I wonder what it takes to get that stuff?
Clair
Re: paint job on a budget!? [Re: Clair_Davis] #21859
02/13/06 12:43 PM
02/13/06 12:43 PM
Virginia
BSharp Offline
BSharp  Offline
Virginia
Here's a polyurethane Rust-oleum that uses a hardener. Since it's catalyzed, I wonder if you could roll it on full-strength and wet-sand and buff after just one or two coats?
Re: paint job on a budget!? *DELETED* [Re: 70Coronet500Vert] #21860
02/13/06 06:07 PM
02/13/06 06:07 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Post deleted by Ira
Re: paint job on a budget!? [Re: BSharp] #21861
02/13/06 09:08 PM
02/13/06 09:08 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I just got off the phone with a local Kelly Moore that carries the industrial line of Rustoleum (they are the only KM in Sacramento that carries that line).
edited: they only sell water based stuff in CA now, which from a bit of googling I found is probably not going to work well.
Looks like it will be rustoleum "professional" from lowes..
Re: paint job on a budget!? [Re: Exit1965] #21862
02/13/06 09:30 PM
02/13/06 09:30 PM
Bellevue, WA
Blackwidow69 Offline
Ring Knocker
Ring Knocker
Bellevue, WA
It may not just be California either. I tried to get some oil based semi gloss paint for the trim in my house from Lowe's and the paint gal said they are getting rid of all their oil based stuff. Strangely enough it is Olympic Fasthide Alkyd based semi-gloss enamel. Went on and acts just like the Porter oil based enamel we were using but I think the water based stuff is what everyone is going to. Exit1965 did the guy say they could not even get the professional rustoleum anymore. I still think that is our best bet in the states.
Todd
Sorry didn't see your last line there!
1969 Ply Roadrunner, 383 4-speed on street tires. 3,830 lbs race weight. Best 1/4: 13.1 @ 106.83 440 & overdrive 4 speed going in. 2005 Power Wagon 35X12.5 KM2's
Re: paint job on a budget!? [Re: Blackwidow69] #21863
02/13/06 09:50 PM
02/13/06 09:50 PM
New Kent, Virginia
matts69Dart Offline
matts69Dart  Offline
New Kent, Virginia
I am sort of ignorant when it comes to automotive paint, so I was wondering something. Is regular auto paint, PPG, etc., oil-based or alkyd based? Thanks all for some great info. Being on a very tight budget, I am a poor school teacher, this has really given me hope of ever getting my Dart painted. As you can see from the pic, primer seems to be my favorite color right now. My wife is from Nova Scotia, so maybe I can get her mom and dad to send me a gallon of Tremclad. My birthday is coming up. Hmmm........Matt
Re: paint job on a budget!? [Re: Blackwidow69] #21864
02/13/06 10:01 PM
02/13/06 10:01 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
there does appear to be this stuff which is all US legal apparently:
http://www.rustoleum.com/product.asp?frm_product_id=495&SBL=2
the guy didn't mention it so i'll have to ask him about it specifically.
Re: paint job on a budget!? [Re: matts69Dart] #21865
02/13/06 10:03 PM
02/13/06 10:03 PM
Bellevue, WA
Ring Knocker
Ring Knocker
Bellevue, WA
Pretty ignorant on auto paint here as well. I just did a search on the net and came up with this brief history. As you can see alkyd enamels are actually mentioned but from the 1930's!!
Synthetic Enamel: In the mid 1930's, a new and completely different type of paint was developed, the alkyd or synthetic enamels. It proved to have superior qualities in film strength, adhesion, luster, flexibility and durability over all previous paints. The resin base was developed from the reaction between phthalic anhydride and glycerin, with gums, oils and plasticizers added during the manufacturing process a drying oil such as linseed, a polyhydric alcohol, such as glycerine, and a dibasic acid, such as Phthalic Anhydride. It dries by solvent evaporation, like the lacquer paints, but the resin remains soft and sticky when no solvents are present. It cures to a hard finish by absorption of oxygen from the air. The curing process can be accelerated by heat, and several methods of baking enamel were developed. Unlike lacquer, when dry, it needs no polishing to produce a high luster finish. Acrylic Lacquer: As time passed, chemists developed a substitute for nitrocellulose lacquer, using an acrylic resin as a base. The resins used in acrylic lacquer tend to be slightly brittle. This deficiency is overcome by the use of a plasticizer ( a liquid that is a solvent for these resins and softens them slightly). A cellulosic resin is any resin derived from cellulose (pure cotton). Acrylic lacquer was used extensively by General Motors. Acrylic Enamel: During the late 1960's and early 1970's, technology brought on the development of acrylic enamel, which was harder and more durable. Chemically, it is a cousin to synthetic enamel, but is modified with acrylic resin, and is not soft and sticky with no solvents present. It cures further with the absorption of oxygen from the air. Unlike the lacquers, which remain soluble in solvents, the enamel family is insoluble in solvent when cured. An acrylic resin is chemically any polymer whose basic monomers are chemical derivatives of acrylic acid. Polyurethane Enamel: In the mid 1970's, polyurethane enamel was developed to withstand the severe stress of high speed airplane surfaces, which are subject to rapid temperature changes and flexing. This paint was much more durable than the acrylic enamels. Acrylic Urethane Enamel: Acrylic urethane enamels were developed to withstand environmental elements, such as acid rain and ultra violet rays. It is the most durable paint to date.
Don't see anything about oil based enamel but doesn't mean it is not one of these with a different name. Anyway acrylic enamel and urethane enamel are what you can buy cheap on ebay and spray yourself as a single stage paint.
Todd
Re: paint job on a budget!? [Re: Blackwidow69] #21866
02/13/06 11:23 PM
02/13/06 11:23 PM
Chicago suburbs
dartgame Offline
dartgame  Offline
Chicago suburbs
This is a really interesting post.......I've been loosely following this thing since it started.
The last post sparked my chemistry side (what I do for a living) so I felt like its time for me to add some additional complexity to the discussion!!! Haha.
Alkyds as noted in the last post are old as the hills chemistry. Here's my .02 worth: Alkyds have free hydroxyl groups, which offer the possibility of crosslinking them using IPDI and HDI (Isophorone Diisocyanate and hexane diisocyanate) trimer(s), these isocyanates are usually used in most modern 2k clears urethane along with acrylic polyols as the main resin.
Problem is... one has to have an idea of how much isocyanate to add to the alkyd. Unless you can get a precise recommendation from the alkyd maker on how much of these isocyanates to add, I dont suggest doing this. There is a chemical balance that should be obeyed called stochiometry, this is the balance between the isocyanate and the free hydroxyls in the paint. Unless you match these fairly closely you can create alot of problems, bubbling peeling etc. However, if you are successful you will have created a urethane modified alkyd car paint. Something that is commonly used in 3rd world car repair, either that or your local Earl Scheibs..haha. Anyway keep in mind that if you do add isocyanates to your paint, the pot life (or application time before hardening) will be reduced to several hours regardless of whether the paint is closed can or open.
What will really annoy everyone about car paint (or any paint for that matter) is how cheap the raw materials are, and how bad the public gets gouged. Don't ask.
Re: paint job on a budget!? [Re: Exit1965] #21867
02/14/06 01:02 AM
02/14/06 01:02 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I thought back, and I thought I could have done enough wrong with my first test to have my paint turn out as easily scratchable as it was. On my test area, I preped the surface with 150 then dusted with a rag, and I used water to clean the foam roller (not a good idea, and not fun). It could be I had dust left on the surface, and/or got some water mixed in with the paint mixture as I applied it (since I reused a roller that had some water hiding in it).
so I'm trying it again using the same stuff, but this time I'm using only mineral spirits to clean the roller, and I sanded the surface with 80, then 240, then cleaned it with mineral spirits and a rag and let it dry.
So I've just applied the first coat..and I'll scratch test each coat until I'm done.
I wonder how the "clear" rustoleum would do, if applied full strength (or thinned?) over a 6 coats of thinned color (+ wetsanding). It might help a bit with gloss or add to scratch resistance.
Re: paint job on a budget!? [Re: dartgame] #21868
02/14/06 01:03 AM
02/14/06 01:03 AM
Massachusetts
Faust Online content
Faust  Online Content
Massachusetts
Has anyone looked into the possiblity of ordering the Tremclad from Canada? Seems to me that is the obvious solution. I mentioned it to my local paint guy, he suggested Canadian paint would not be importable, high VOC's or something. Could be he was just "playing smart".
Re: paint job on a budget!? [Re: Faust] #21869
02/14/06 01:07 AM
02/14/06 01:07 AM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
next time I go see my bro in buffalo, I might have to take a ride. Think they would hassle me at the border for a gallon of paint?
