Re: 1 3/4 or 1 7/8 header ????
[Re: 451Mopar]
#2185797
10/30/16 01:18 PM
10/30/16 01:18 PM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
Who makes the 1-3/4" headers? All I usually see are 1-7/8 or 2"? Summit has a set for $120? I had them on my tired 440 which ran 12.0's at 113 mph a few weeks ago in my GTX. They fit great!
"I think its got a hemi"
[Re: AndyF]
#2185798
10/30/16 01:19 PM
10/30/16 01:19 PM
gdonovan
Oakdale CT
My pump gas 470 makes 700 hp with 2 inch headers on the dyno. I tried a set of 1 3/4 headers to see what would happen and it still made 690 hp. Ouch! I just upgraded from 1 3/4 to 1 7/8 to make a touch more power. Wanted ceramic coated anyways! lol!
[Re: gdonovan]
#2185851
10/30/16 02:32 PM
10/30/16 02:32 PM
RapidRobert
with header fitment being the pain that it is, that would be far more important & I would get a set that fits the best (which wont be the 2") whether it be 1&3/4 or 1&7/8
[Re: fast414]
#2185870
10/30/16 02:54 PM
10/30/16 02:54 PM
Posts: 728 Michigan
BlueRacer69
Like Robert said, fitment plays a big part in your choosing the size. With that said, I think tti makes a 1 3/4 size header or they use to. Of course they will cost a lot more then Summit's price of $120.00.
[Re: 383man]
#2188593
11/03/16 10:23 AM
11/03/16 10:23 AM
Posts: 9,875 Weddington, N.C.
Streetwize
Weddington, N.C.
At 440" and a .557 the 1 3/4" will be fine but IMO it's important to remember the collector size will tend to limit the RPM that peak torque will be produced, so if the collector is too small for the compression and cam it will lower the HP trajectory (rate of HP rise per 100 rpm) beyond the peak torque RPM. It's pretty easy to adapt and weld a larger slip on collector (such as the ones sold by Shoenfeld) to inexpensive headers, Generally, a 3 1/2" collector will likely pick up your HP compared to a 3" even with the same primary tube sizes, all else being equal. That is provided/assuming you will also have a low restriction system downstream of it. ET improvements can be found when the converter, cam and collector size are optimally tuned for one another.
