Rocker shaft is not sitting flush... #2185226
10/29/16 12:33 PM
10/29/16 12:33 PM
houston, tx
d100clubcab Offline OP
houston, tx
Hey how's it going?
http://i.imgur.com/7UtBLS3.jpg
http://i.imgur.com/VQK7K2s.jpg
I'm trying to put my rocker arms back on but they won't sit flush in the head girdle thing. This doesn't seem right to me. Also, the rocker shaft bolts don't even snug down the retaininer/clip that separates the rockers.
Ideas????
Re: Rocker shaft is not sitting flush... [Re: d100clubcab] #2185255
10/29/16 01:22 PM
10/29/16 01:22 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Are you sure you have the right bolts? The shaft is supposed to pull down when you tighten the bolts. Remember you have valves open and that puts pressure of the shaft to hold it off the supports
Re: Rocker shaft is not sitting flush... [Re: stumpy] #2185276
10/29/16 01:45 PM
10/29/16 01:45 PM
keep an eye on the distance between the bottom of the shaft and the (5) saddles & tighten the bolts evenly so the distances stay the same as you tighten em down a little at a time. What Stump said, some valves will be free (& their respective bolts will turn easy) and some will be under tension (& their respective bolts will turn hard) but stick to the plan & keep the gaps even, as they decrease with turning the bolts down
Re: Rocker shaft is not sitting flush... [Re: RapidRobert] #2185317
10/29/16 03:06 PM
10/29/16 03:06 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Also make sure all pushrods and rockers line up correctly and are seated before beginning to snug down the bolts. twocents
...FAFO...
Re: Rocker shaft is not sitting flush... [Re: skicker] #2185336
10/29/16 03:30 PM
10/29/16 03:30 PM
iagree I take the oil dipstick out and lay it across the rocker pedestals to hold the pushrods aligned while tightening the bolts down scope
I have bent stock pushrods by not keeping them aligned while tightening the bolts runaway puke realcrazy
Good luck, take your time and get it correct the first time up
Re: Rocker shaft is not sitting flush... [Re: skicker] #2185339
10/29/16 03:32 PM
10/29/16 03:32 PM
Agreed, & a thin straight length of non flux coated (bare) welding rod wire is good for that
Re: Rocker shaft is not sitting flush... [Re: Cab_Burge] #2185401
10/29/16 05:53 PM
10/29/16 05:53 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
That's a neat trick.
I'll have to remember that one.
I have mechanical Aptitude.
I can screw up anything.
Re: Rocker shaft is not sitting flush... [Re: d100clubcab] #2185425
10/29/16 07:14 PM
10/29/16 07:14 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Take the shaft back off of there and run those bolts down to be sure they're not galled or hydrolocked. I've seen a couple of them bolts galled over the years for limited reasons. 'nuther words, I dunno!
Re: Rocker shaft is not sitting flush... [Re: d100clubcab] #2185436
10/29/16 07:35 PM
10/29/16 07:35 PM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
drop the wrench and step away from the vehicle... call for help
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: Rocker shaft is not sitting flush... [Re: d100clubcab] #2185437
10/29/16 07:36 PM
10/29/16 07:36 PM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
Drop the wrench and step away from the vehicle... call for help
Re: Rocker shaft is not sitting flush... [Re: d100clubcab] #2185595
10/29/16 11:05 PM
10/29/16 11:05 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Longer bolts in two center pedestals only!
Re: Rocker shaft is not sitting flush... [Re: d100clubcab] #2185821
10/30/16 01:51 PM
10/30/16 01:51 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I finally was able to see the pictures ...
The rocker shafts will not sit flush against the pedestals when you are assembling them onto an engine that has a CAM AND LIFTERS installed because all your valves are CLOSED and some of them will be OPEN, to varying degrees, once the shaft is torqued in place.
Do as stated above and make sure the pushrods are in the right postilions and slowly tighten all the bolts one by one , end to end till you get the shafts against the pedestals then torque them to spec .
