Recommendation On Where To Buy Sending Unit
#2185241
10/29/16 01:05 PM
10/29/16 01:05 PM
Posts: 755 Tempe, AZ
loco340cuda
Tempe, AZ
I need to buy a sending unit for my 70 Cuda, (340ci engine).
The last one I bought I got from Classic Industries and it appears to be non-functional after I installed it. I verified the gauge is working properly and the tank has good ground. When measuring the resistance of the sending unit I get 18Mohm reading which says the unit is not working correctly.
Given that I don't want to have to replace the unit a third time, I am looking for a recommendation on where to buy one of these that is of better quality.
I understand with the exception of NOS all the aftermarket ones are not that good but I at least want to buy one that is functional and is reasonably accurate.
Also, is it possible to swap out the sending unit without having to drop the tank?
70 Cuda 340 4 speed - now stroked to 416ci (SOLD) 2017 Mustang Shelby GT350
Re: Recommendation On Where To Buy Sending Unit
[Re: loco340cuda]
#2185257
10/29/16 01:24 PM
10/29/16 01:24 PM
Posts: 3,379 KY USA
mopargem
KY USA
This should work from sponsor Dixe Resto http://ebay.to/2ePrUvl
68 Polara 500...LL1 Y7 M6X 69 Hemi road runner...X9 X9 M6X 69 A12 road runner....R4 R4 M6X 69 ModTop FLORAL Super Bee...F6 M6W 70 AAR 'cuda...EW1 EW1 H4X9 71 Duster 340...FJ6 V24 L6X9 71 road runner FC7 V1X M6X9 72 Rallye Charger B5 V1W 74 'cuda 360...KB5 V1X A6X9 08 SRT Challenger #234
[Re: loco340cuda]
#2185294
10/29/16 02:26 PM
10/29/16 02:26 PM
RapidRobert
Also, is it possible to swap out the sending unit without having to drop the tank? yes if the sender goes in the side of the tank (& most do) & it does on your 70 cuda. My 85 ramcharger I think I am fubared (& it is on empty)
[Re: loco340cuda]
#2186618
10/31/16 12:44 PM
10/31/16 12:44 PM
Posts: 1,822 Colorado
denfireguy
Colorado
Also, is it possible to swap out the sending unit without having to drop the tank? 81 Megohms is leakage resistance. If your ground is good, the sender is open. You probably have lower leakage resistance holding a probe in each hand. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: loco340cuda]
#2188223
11/02/16 07:31 PM
11/02/16 07:31 PM
denfireguy
Colorado
Finally found one that works but it came with the entire tanks. Spectra CR8CFI fuel injection tank with sender and pump. Full is 8 ohms and full deflection of gauge. Empty is empty. First aftermarket one that had done that for this car. Craig
[Re: tman]
#2188331
11/02/16 09:40 PM
11/02/16 09:40 PM
loco340cuda
Tempe, AZ
Thanks. I ordered the NOS one from Dixie on eBay on Saturday. Just waiting to hear from them that it actually shipped.
[Re: loco340cuda]
#2188392
11/02/16 11:02 PM
11/02/16 11:02 PM
loco340cuda
Tempe, AZ
So just checked the mailbox and the sending unit was in there. I went out and measured the resistance with the float low (equivalent to empty tank) and it measured around 78ohms. When I raised the float to simulate a full tank the resistance went down to about 16 ohms at about 4/5 full and then creep back up to 78 ohms at full. I did this a bunch of times and it was fairly consistent. Then I tried it by raising the float very slowly and I could get it to read 13 ohms at full. I tried doing this repeatedly (raising it slowly) but could not always get a 13 ohms reading every time (sometimes ~20 ohms, sometimes ~30 ohms and every now and again 78 ohms). Does this sound right or do you guys think this OEM sending unit has an issue?
[Re: mikemee1331]
#2188733
11/03/16 02:19 PM
11/03/16 02:19 PM
RapidRobert
that does sound like a big spread to me, maybe (hopefully) the contact pressure of the tang on the windings is varying as you manually move it out in the open & maybe it'll be different when installed with it immobile.You might with some jumpers wire it up to the blue sender wire at the tank & ground it & work it & have a helper holler what the gauge is showing. unfortunately that might be close to what you are doing now by just ohming it but I'd wanna do as much as I could before installing it & potentially having to go thru the mess of a R&R. keep us posted
