Need a set of Small Block aluminum heads.....differences? #2184461
10/28/16 12:45 PM
10/28/16 12:45 PM
Down South
DaKuda Offline OP
DaKuda  Offline OP
Down South
I'm looking to buy a set of aluminum heads. As far as Indy what is the difference between the rectangular and oval port. Why one over the other? If any of you guys have anything for sale send me a message.
Re: Need a set of Small Block aluminum heads.....differences? [Re: DaKuda] #2184468
10/28/16 12:52 PM
10/28/16 12:52 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Ryan doesn't post here anymore but there is a lot of good info on his website. It would help to know how fast you are looking to go and what you expect out of the heads. My next two sets that I purchase for small blocks will probably be a set of ProMaxx heads and the new Edelbrock Victor small block head.
http://shadydellspeedshop.com/
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Need a set of Small Block aluminum heads.....differences? [Re: DaKuda] #2184485
10/28/16 01:11 PM
10/28/16 01:11 PM
Down South
DaKuda Offline OP
DaKuda  Offline OP
Down South
I looked at the new Victor head but unless I am looking at it wrong they are $4,000 for just two heads??
Re: Need a set of Small Block aluminum heads.....differences? [Re: DaKuda] #2184486
10/28/16 01:12 PM
10/28/16 01:12 PM
Down South
DaKuda Offline OP
DaKuda  Offline OP
Down South
I'm putting a small block Chrysler in a 2003 Mustang. I want the car to run around 6.50 in the 1/8th.
Re: Need a set of Small Block aluminum heads.....differences? [Re: DaKuda] #2184496
10/28/16 01:25 PM
10/28/16 01:25 PM
PA.
"Little"John
"Little"John
PA.
You can do the easily with ported Edelbrock or ProMaxx heads. My Sons 3150 pound Duster has gone 10.40's with a 360, 520 lift Racer Brown cam, ported Edelbrock heads with a 2.05 valve, and a 727 transmission and 4.10 gears.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Need a set of Small Block aluminum heads.....differences? [Re: pittsburghracer] #2184532
10/28/16 02:26 PM
10/28/16 02:26 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
https://board.moparts.org/ubbthreads/ubbt...nder-heads.html
Call Rod this head will smoke any of the other stock replacement type heads. You
