Best way to clean fuel tank, without removal.
#2183203
10/26/16 07:46 PM
10/26/16 07:46 PM
Posts: 2,346 west palm beach, florida
modelmakerinc
Guys, I have a one year only fuel tank that I cannot get any seals, rubbers, or sending unit, what is the best way to try and flush what is still in it and clear out the sender.
I know if I remove to clean, I will run into leaks and damage to the seals
Re: Best way to clean fuel tank, without removal.
[Re: modelmakerinc]
#2183269
10/26/16 09:33 PM
10/26/16 09:33 PM
Posts: 13,610 md
mopars4ever
md
[Re: modelmakerinc]
#2183279
10/26/16 09:41 PM
10/26/16 09:41 PM
modelmakerinc
I've seen that sending unit but 76 and 77 tanks are seriously different, my understanding is that sender does not work on a 76 despite his ad.
I get conflicting opinions, on fitment but I will investigate into that part again. Thank you very much.
Where is the seal from?
[Re: mopars4ever]
#2183286
10/26/16 09:46 PM
10/26/16 09:46 PM
RapidRobert
Since it shows the seals etc are available I would highly suggest taking it out & getting it spot on clean. If it is real bad I would consider a new tank, (you're sure they ain't available anywhere?) As far as brands I've used Spectra from Canada several times. If I had to clean one out WO removing it I would hit it with the car wash wand then siphon out the sudsy water & repeat with clean water several times & siphon most of it out then a heater under it to evaporate the rest of the moisture. Just me if I could get a new tank I would as minute debris will cause havoc with carb systems no matter what filter you have
[Re: modelmakerinc]
#2183290
10/26/16 09:49 PM
10/26/16 09:49 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Not sure why you cannot retrofit the later, more common tank in?
[Re: modelmakerinc]
#2183351
10/26/16 10:44 PM
10/26/16 10:44 PM
Posts: 13,610 md
mopars4ever
md
If you end up only needing the gasket, http://www.rtspecialties.net/proddetail.asp?prod=1948757 Then again, i`m not sure if that is NOS but that is the correct part number. The sending unit is at the front lower part of the tank and the tank needs to be empty when removing the sending unit. It won`t be a issue for you since you are removing the tank as a assembly I assume. Do not use the aftermarket lock ring. They are flimsy at best and will cause issues. At me how I know, LOL. Use the old one if it`s in good shape or look for NOS. I believe the filler tube seal was still available from dodge last time I checked. I actually used a NOS sending unit seal because the aftermarket was a different rubber from OE and I didn`t trust it after the first mishap.
[Re: modelmakerinc]
#2190806
11/06/16 05:14 PM
11/06/16 05:14 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I am going to use either the berrymans 1 gallon cans of carb cleaner and fill the tank with that or methylene chloride, that should remove the varnish and sludge...
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
