Help: Any other blocks use MP R3 4 bolt main kit P5249669 ?? #2182712
10/26/16 12:47 AM
10/26/16 12:47 AM
So Cal
autoxcuda Offline OP
So Cal
Mopar Perf R3 4 bolt main cap package P5249669
Do these fit?:
-X-block
-340 "resto" block
-any other block
Trying to get info on this for buyer before I take it to swap meet. It might really help a guy with an old X block kicking around that lost it's caps over the years.
Re: Help: Any other blocks use MP R3 4 bolt main kit P5249669 ?? [Re: autoxcuda] #2182749
10/26/16 02:04 AM
10/26/16 02:04 AM
P
Porter67 Offline
Porter67  Offline
P
They interchange with what you listed. 10-12 years ago ebay was flooded with them at under $50 a set.
Ryan J was selling them with arp stud kits for under $150 iirc.
You can still cut the ends off and use them for a new set of hd caps or you can press in sleeves and us a smaller then 1/2 bolt on the outers on an oem block.
Are them for a 340 or 360 main crank?
Re: Help: Any other blocks use MP R3 4 bolt main kit P5249669 ?? [Re: Porter67] #2182755
10/26/16 02:19 AM
10/26/16 02:19 AM
So Cal
So Cal
That part number is 318/340 mains with all 5 caps. Per 2002 MP catalog pg 102
Did those other sets come with all 5 caps?
