I've used sealed power cam CS1019R with good results. Specs are 214-224 duration @ .050, lift is .443int,.466ex, with a 112cl.
Is that a 340 replacement cam? What was the rest of the combination?
Just curious what the gear/converter and such was.
I actually ran a MP 284/0.484" cam in a stock block 318 with 4-bbl and headers. No power below 3,000 RPM, but with gears and a high stall converter it was good at the track. I'm not sure how many modifications and $$$ the original poster wants to invest in?
