Re: Ignition key assembly
[Re: dickdale]
#2182359
10/25/16 06:06 PM
10/25/16 06:06 PM
Posts: 6,433 Abilene, Texas
fastmark
Abilene, Texas
Where are all the springs and top plate that holds them in?
[Re: dickdale]
#2182777
10/26/16 03:04 AM
10/26/16 03:04 AM
RapidRobert
I've only worked with the ones with the chrome removeable covers & these might be the same & you need to mix and match the tumblers and the spacers so that the height of a tumbler/spacer combo along with the height on the notch all together lets the "split" where the tumbler meets/contacts the spacer on all (5) of be at the right height (flush with the top of the inside cyl) so the cylinder can rotate/turn in the lock itself. in other words nothing protruding to shallow or to deep that keeps the cyl from turning & each key notch depth & tumbler and spacer heights all combine in height to achieve that. if you lose some parts no big deal as no one picks locks any more (except in the movies) at least in the US of A so (2) functioning holes per lock is fine. what Fastmark said, gotta find or fab the plate & peen it
