Help ID'ing E-body radiator, shroud, and 70 floorshift #2181943
10/25/16 02:12 AM
10/25/16 02:12 AM
So Cal
autoxcuda Offline OP
So Cal
Is this shroud factory 22" or repro
What is the application of this radiator? PN appears to be 3820991, but I cant find it in the ID guides.
Also does anyone have a measurement to ID this 70 only floor shift column as Power OR Manual steering ??
70 Ebody floorshift with 70 only lockout. ??? Power or Manual Steering???
Re: Help ID'ing E-body radiator, shroud, and 70 floorshift [Re: autoxcuda] #2181948
10/25/16 02:27 AM
10/25/16 02:27 AM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
looks like power steering
scope
~13" for power steering
Re: Help ID'ing E-body radiator, shroud, and 70 floorshift [Re: autoxcuda] #2181958
10/25/16 02:55 AM
10/25/16 02:55 AM
So Cal
So Cal
yep power steering. I just measured 13 1/2" or so.
I have a 71-74 that was longer that I wanted to use for backup parts for my '71 Column. Well, that one is a manual steering. rolleyes
Any ideas on the radiator? or shroud?
Re: Help ID'ing E-body radiator, shroud, and 70 floorshift [Re: autoxcuda] #2181974
10/25/16 04:18 AM
10/25/16 04:18 AM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
whistling
truck radiator & I don't think there is a reproduction 22" shroud available with a pentastar/part number/vendor code shruggy is there?
Re: Help ID'ing E-body radiator, shroud, and 70 floorshift [Re: autoxcuda] #2181979
10/25/16 04:47 AM
10/25/16 04:47 AM
So Cal
So Cal
Cool. Thanks.
