Re: Best Battery for a drag car only? And maintenance?
[Re: DemonDust]
#2181393
10/24/16 01:38 PM
10/24/16 01:38 PM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
If it is still working after 8 years I would say your taking care of it just fine. I have been pleased with my Optima Yellow Top, its 6 years old now and I just tested it a month or two ago and it still passes a load test at full CCA with no problem at all.
68 Barracuda Formula S 340
[Re: DemonDust]
#2181395
10/24/16 01:42 PM
10/24/16 01:42 PM
Thumperdart
State of confusion
Been running 2 Orbital gels for many years and they rock and last years as long as you keep em somewhat charged up.........
[Re: DemonDust]
#2181480
10/24/16 03:13 PM
10/24/16 03:13 PM
Posts: 43,262 Bend,OR USA
Cab_Burge
Have someone check the cranking voltage drop on the battery when cranking it Let us know what the drop is Are you running a alternator or charging the battery after each run?
[Re: DemonDust]
#2181493
10/24/16 03:29 PM
10/24/16 03:29 PM
Cab_Burge
Can I just watch the battery read out on my Racepak? That should be a real time voltage drop right? Or is that not accurate enough. I really don't know Do you turn the racepak on after staring it or before? I see a lot of racers that have someone turn the Racepak on just before the run and the diver shuts it off with a master kill switch at the end of the runs
[Re: DemonDust]
#2181534
10/24/16 04:28 PM
10/24/16 04:28 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
When cranking the battery drops from 12.6 to 7.8-8.1
That's what my Racepak dash reads.
[Re: DemonDust]
#2181549
10/24/16 04:49 PM
10/24/16 04:49 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I have head of optima batteries causing electrical glitches, never used them my self. Worth a try if you ask me. Take the battery out of the daily driver and try that.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: DemonDust]
#2181550
10/24/16 04:50 PM
10/24/16 04:50 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Min. should be 12.4 while cranking. Battery needs replacing.
JAKES AUTOMOTIVE
[Re: DemonDust]
#2181561
10/24/16 05:04 PM
10/24/16 05:04 PM
Posts: 8,174 Plymouth, MI
Blusmbl
Plymouth, MI
A dip to 10v during crank isn't uncommon at all. I've seen as low as 6v when the starter initially engages. I'd take yours to Autozone/OReilleys/NAPA and have them load test it for certain.
[Re: DemonDust]
#2181566
10/24/16 05:16 PM
10/24/16 05:16 PM
Posts: 2,673 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Let me get this straight. Your battery lasted 8 years and you're asking us what kind of battery to buy? I think you should be telling us what battery to buy. I've almost never had a battery in anything last over a couple of years. Me and batterys have bad mojo.
2011 Drag Pak Challenger
[Re: DemonDust]
#2181583
10/24/16 05:38 PM
10/24/16 05:38 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
That's what my Racepak dash reads. If that is the case, the battery is junk or something in the starting circuit is drawing crazy amps
[Re: DemonDust]
#2181590
10/24/16 05:53 PM
10/24/16 05:53 PM
Posts: 19,379 Las Vegas
Al_Alguire
Las Vegas
My opinion if it is a race car is go 16 volt and NEVER look back..
