Re: steel vs fiberglass [Re: rowin4] #2178999
10/20/16 07:45 AM
10/20/16 07:45 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I built some glass/carbon farings from scratch for my airplane, 3 plies total, they were strong enough to stand on and when I painted them, they doubled in weight. I also made the molds using glass matt cloth and they fit perfectly because I made them right on the cowling. good luck tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: steel vs fiberglass [Re: rebel] #2179166
10/20/16 02:40 PM
10/20/16 02:40 PM
iagree up Same thing on my tube chassis 1970 Cuda with the slide off front end, it has the OEM steel fenders and stock steel upper an lower valances still with aluminum inner fender wells shruggy
Re: steel vs fiberglass [Re: Cab_Burge] #2179388
10/20/16 09:39 PM
10/20/16 09:39 PM
gulfport, ms, west mi
rowin4 Offline OP
rowin4  Offline OP
I've got the aluminum inner fender wells built also, but the way there made to fit they wrap over the front down tubes and captures the front motor plate. No slipping this one off without some major mods.
Re: steel vs fiberglass [Re: rowin4] #2179692
10/21/16 12:56 PM
10/21/16 12:56 PM
rowin4 Offline OP
rowin4  Offline OP
Reading up on fiberglass repair, doesn't look that hard, just messy. I did some glass work back in the 60's . looked like crap but it patched the hole.
