Re: air/fuel monitor kit
[Re: RonaldV]
#217862
02/08/09 02:10 PM
02/08/09 02:10 PM
I don't think you really need more than one.. but whatever you do.... I would use these guys http://www.innovatemotorsports.com/you need a controller to read wideband o2 sensors, their box will read up to 5 inputs, I think.. so would read one or both of your sensors, and a tach signal so you can do some data logging and figure out how at what RPMS you need to do your adjusting.
#217863
02/08/09 02:18 PM
02/08/09 02:18 PM
RapidRobert
I would get the innovate LM1 wide band unit with the add on rpm converter & since you have bungs welded in on each side I would get 2 sensors. It's extra $$$ but you'll then have everything monitored
