Haha. Idk how much younger I am...44. My son is 14 tho and this will be his truck at some point. It will donate itself to a 1950 Studebaker pick up body. studeakota??
I'm going to see if I can keep the stock pump and wiring and plumbing I guess. If so then a regulator. If not I will pull the stock electric pump motor and run a small Holley electric pump suction line into there I guess
I thought about putting the cam eccentric on but I already have the engine cleaned and regasketed and painted
I would post a pic but I don't see the paper clip attatchement on top
Rich[size:14pt][/size]
Like I suspected , your 12 years younger than I am, can't speak for RR. Not that is a bad thing, your a lucky guy to be younger.
It is best to keep and use the original in tank pump. Why not? The return is the way to go too with today gas and is the "hot ticket" on a hot day.
Otherwise you would have to custom fabricate a cover and pickup tube to go where the existing fuel pump mounts and then you would have a poorly designed pickup point for a external pump and like I said it would not be gravity fed for the noisy external pump that would vapor lock on hot days because of the pickup. Pumps can't suck gas uphill reliably, especially in hot weather.
To post a picture from your computer you click on file manager toward the bottom, but the picture must be small enough to fit. Most new cameras nowadays takes large pictures and they must be resized to fit here.
The other and better way is to host your picture somewhere and then it will be resized automatically to fit here and you can post more than 2 pictures at a time. In that case you use the 4th button from the left at the top of the posting page(not the quick reply page)to copy and paste the direct link to your picture/s.
