Is there n inexpensive way to lower a 96 Ram 1500 2 wheel dr #2178500
10/19/16 12:09 PM
10/19/16 12:09 PM
Freeport IL USA
poorboy Offline OP
poorboy  Offline OP
Freeport IL USA
I'm looking at buying a 96 Ram 1500 2 wheel drive truck. That thing sits awfully high. I'm a bit past the point I want to climb up into a truck, and jump down when I want to get out of it.
Is there an inexpensive way to lower that truck so I won't have to climb in? I'm thinking it needs to drop at least 3", but 6" might be better. It probably won't be hauling more then a couple hundred lbs of weight in the bed at any time, and mostly only 2 people. Gene
Re: Is there n inexpensive way to lower a 96 Ram 1500 2 wheel dr [Re: poorboy] #2178678
10/19/16 05:41 PM
10/19/16 05:41 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You can get a 2" lowering shackle set for the rear but the front is a whole new kettle of fish. A cheap set of tubular steps would be the easiest way to go. The ones on my Ram were $109 shipped. Took about an hour to install and are very solid.
Re: Is there n inexpensive way to lower a 96 Ram 1500 2 wheel dr [Re: poorboy] #2180364
10/22/16 03:46 PM
10/22/16 03:46 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Aren't B van spindles lower than D truck?
Kevin
Re: Is there n inexpensive way to lower a 96 Ram 1500 2 wheel dr [Re: poorboy] #2181183
10/24/16 12:46 AM
10/24/16 12:46 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
i have a set of lowering springs and drop shackles i took off my mexican 2000 ramcharger----the previous owner was running some 20 inch wheels on it and the tires were wearing through the plastic inner fenders----i dont know how big a drop it was but it drove me nuts in a short while...dont know the source of the parts either....
Re: Is there n inexpensive way to lower a 96 Ram 1500 2 wheel dr [Re: poorboy] #2181852
10/24/16 11:37 PM
10/24/16 11:37 PM
Freeport IL USA
poorboy Offline OP
poorboy  Offline OP
Freeport IL USA
Thanks all, the deal on the Ram 1500 fell through. Someone was quicker with the cash then I was. Gene
Re: Is there n inexpensive way to lower a 96 Ram 1500 2 wheel dr [Re: Twostick] #2181897
10/25/16 01:02 AM
10/25/16 01:02 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Kevin
Yes,the vans have a spring pocket that let's a D-series truck sit lower when they are installed.I think it only fits the '93 and earlier trucks though. ~RT
