Steering column ground wire- 70RR #2178141
10/18/16 10:16 PM
10/18/16 10:16 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Someone have a pic or description of attachment points.. getting ready to install column... and the wire was in a bag.... shruggy
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Steering column ground wire- 70RR [Re: JMCFAN] #2178156
10/18/16 10:33 PM
10/18/16 10:33 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
from one of the bolts that hold the dash mount bracket to the column and then other end to screw under dash . ..if I recall correctly . . .would have to go to the 70 satellite and see . . .
Re: Steering column ground wire- 70RR [Re: JMCFAN] #2178350
10/19/16 01:44 AM
10/19/16 01:44 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The other end on the mounting stud column to dash, with another nut securing the wire on top of the first nut to mount the column.
