Re: sub frame connector question (65 Coronet)
[Re: Littsen]
#217775
02/08/09 02:11 PM
02/08/09 02:11 PM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
Ill be doing the same to my 65 Belvedere soon.Im thinking about moving the spring holes an inch also so I can run the 67 up springs instead of the shorter front 65s.Rocky
Chrysler Firepower
[Re: therocks]
#217777
02/08/09 02:39 PM
02/08/09 02:39 PM
Posts: 735 Spokane,WA
Genuinejed
Spokane,WA
I just installed 2X3 connectors in my 65 sedan. I bought the connectors in 4' sections, but next time I will go longer. I could have extended them another 6" into the longitudals. It probably isn't that big of a deal, but I'll take all the rigidity I can get! I welded up some connectors in a freinds dart and he made his the way you're suggesting. He fit the connectors in the car and extended them all the way through the frame to the relocator hanger. Once the original frame was notched for the relocator hangers, we welded the hangers to the connectors and slid them through the original frame and welded them in. I thought this was a pretty cool idea at the time, and if I was using a relocation kit I would have done it the same way. Good luck!!
1968 Plymouth road runner
1968 Dodge Coronet 500
64 D200
Good, Fast, Cheap. Pick Two.
