steel vs fiberglass #2176842
10/17/16 01:26 PM
10/17/16 01:26 PM
gulfport, ms, west mi
rowin4 Offline OP
rowin4  Offline OP
70 cuda front fenders. Does anyone have a weight difference between the two? I know there is different weights of fiberglass, race or street but just need a idea on what each might weigh.
Re: steel vs fiberglass [Re: rowin4] #2176850
10/17/16 01:33 PM
10/17/16 01:33 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I know my pair of fiberglass fenders for my Road Runner are 28lbs lighter then the pair of steel fenders. Cuda fenders would be fairly close in weight.
69 GTX 68 Road Runner
Re: steel vs fiberglass [Re: JERICOGTX] #2177032
10/17/16 04:43 PM
10/17/16 04:43 PM
rowin4 Offline OP
rowin4  Offline OP
28 pounds is quite a difference, I'll have to rethink this option.
Re: steel vs fiberglass [Re: rowin4] #2177141
10/17/16 07:17 PM
10/17/16 07:17 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
I remember when I helped my friend build his ss/a car back in the late 70's we weighed a factory ss fender and it was 18 lbs. a after market was 16lbs. and a steel was 24 lbs. The biggest gain was in the hood.
JAKES AUTOMOTIVE
Re: steel vs fiberglass [Re: rowin4] #2177148
10/17/16 07:22 PM
10/17/16 07:22 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I never weighed my front end, but I pulled the steel front end off of my 70 Cuda in 1 piece by myself. The fiberglass front end I installed didn't seem much lighter to me. Hood, bumpers, doors were the biggest weight savings. I don't think I would go with glass fenders again.
[image][/image]
Re: steel vs fiberglass [Re: rowin4] #2177168
10/17/16 07:43 PM
10/17/16 07:43 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
28 lbs, a lot of work to make them look good for .03 in ET.
Doug
Re: steel vs fiberglass [Re: rowin4] #2177176
10/17/16 07:52 PM
10/17/16 07:52 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
My car didn't have any front fenders when I started the project. EVERYTHING on my project has been more work than it's worth, so why not lose some weight. Lol.
Re: steel vs fiberglass [Re: JERICOGTX] #2177246
10/17/16 09:27 PM
10/17/16 09:27 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Agreed if the quality and price are reasonably close. I'm watching a friend do glass fenders on a 64 Polara right now. The outer finish is very good. Fitting has required hours of work to clear the stock rocker/sill and make a headlamp fit. He is picky and they'll look great when done. His day job is a prototype show car builder for Ford.
Doug
Re: steel vs fiberglass [Re: dvw] #2177725
10/18/16 03:21 PM
10/18/16 03:21 PM
rowin4 Offline OP
rowin4  Offline OP
With all the extra metal structure needed to mount the fiberglass, I wonder if it's a wash between the two or pretty close.
Re: steel vs fiberglass [Re: rowin4] #2177739
10/18/16 03:39 PM
10/18/16 03:39 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
My car picked up and was more consistent when I converted to fiberglass.
Re: steel vs fiberglass [Re: rowin4] #2177750
10/18/16 03:51 PM
10/18/16 03:51 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Not if done right and the right parts used. This is an extreme example..........but a carbon fiber nose with a titanium tree on a customers 63 Corvette Pro Mod car weighs 11 pounds, TOTAL. That's fenders, hood and tree, COMPLETE front end.
Our gutted steel fenders, glass bumper, factory grille and header panel, with a glass hood and moly tree, weighed 80lbs on our G-body. The Glasstek nose, with hood and moly tree weighs less than 30lbs with the factory grille installed.
Weight is weight. I rarely look at it as "worth" it, because in truth NOTHING is worth it on a race car. But if I can save a pound, I will
Re: steel vs fiberglass [Re: rowin4] #2177923
10/18/16 05:34 PM
10/18/16 05:34 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
my front clip, doors & trunk lid are made from Kevlar. if i could tape them all together i could lift them above my head with 1 hand. they are thicker than glass but they dont flex & they're super light. if you know someone with the molds you might want to consider Kevlar panels.
Re: steel vs fiberglass [Re: rebel] #2178486
10/19/16 11:50 AM
10/19/16 11:50 AM
rowin4 Offline OP
rowin4  Offline OP
I never heard of kevlar body panels, maybe I'm living under a rock. LOL I'll look into them. I know one thing for sure , carbon fiber is not in my future.
Re: steel vs fiberglass [Re: rowin4] #2178663
10/19/16 05:07 PM
10/19/16 05:07 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i live down under & we have a huge boat building industry. Kevlar & carbon are very commonplace down here. i repaired my Kevlar with carbon matting since it costs the same but much stronger. If you have a mold you probably need to talk to a boat builder.
Re: steel vs fiberglass [Re: dvw] #2178667
10/19/16 05:22 PM
10/19/16 05:22 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Doug
Scary, I was thinking the exact same thing.
Re: steel vs fiberglass [Re: dvw] #2178698
10/19/16 06:25 PM
10/19/16 06:25 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Doug
Pardon me for saying, but frankly this attitude is why most guys cars are tanks. 28lbs is 28lbs. At this point on our car, I would kill to find 28 easy pounds to get rid of. We hacked our t-top roof off to put a carbon one piece roof on and lost 40 pounds. Work? sure, but it was 40 pounds
Too many say that's "only 5 pounds" that won't matter. Take that approach 10 times and you have piled 50 pounds on your car.
Weight is free horsepower and if you don't have a minimum weight, why not make the car as light as you can. Even if it does, you should still make it light and put the weight where you want it
Re: steel vs fiberglass [Re: rowin4] #2178702
10/19/16 06:35 PM
10/19/16 06:35 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I agree with you to a point. #1 Is it in the race budget. #2 (and this happend to be a biggie with me) how does it look? I'd love to have nice carbon body pieces. Beyound my budget though. As we all know not every glass piece is real light or looks good.
Doug
Re: steel vs fiberglass [Re: rowin4] #2178726
10/19/16 07:44 PM
10/19/16 07:44 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
The key is to buy nice glass or MAKE it nice. And just because you buy carbon, doesn't make it nice either. Has to do with quality of molds and the layup. Our carbon doors fit like ass, but our body guy cut them apart and made them fit as good as the steel ones. Nothing about glass you can't fix. Now if guys expect to buy glass parts, bolt them on and they fit and look as good as steel without touching them, well yeah, he should probably stick with steel. It will take some work, but to me the weight savings is worth the work
Re: steel vs fiberglass [Re: rowin4] #2178755
10/19/16 08:39 PM
10/19/16 08:39 PM
rowin4 Offline OP
rowin4  Offline OP
Monte, thanks for your and everyones input. My situation is that I have already have glass fenders, they look good ,but age has taken there toll on them with many cracks/breakouts at the mounting areas top and bottom. All could and probably will be repaired . I was possibly looking for a easy way out with going back to steel fenders. More ridged , less support needed. The car when I bought it was a back half car, now tube chassis which now requires support for the fenders that are not really ready for that. I don't plan to have a one piece take off front so I guess I'll just get some tubing and start making attachment points.
Re: steel vs fiberglass [Re: rowin4] #2178989
10/20/16 04:25 AM
10/20/16 04:25 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
Honestly, having a nice tire to sit on as you service under your rocker covers or intake system is so much better than bending over n reaching down. I have big blocks in both my race car n street car n working on the racecar with the front clip removed is so much better.
