Rear brake noise from drilled rotors #2177205
10/17/16 08:35 PM
10/17/16 08:35 PM
Rittman Ohio
fourgearsavoy Offline OP
Rittman Ohio
I have Wilwood Dynalite brakes on the rear of my Savoy and they have drilled rotors(not my choice I just got a smoking deal on them)that make noise whenever step on the brakes.
I was just wondering if this is a normal sound that will go away after a while or are they just like that. I'm probably just going to get a new set of solid rotors and see if the noise goes away.
Anybody need a set of drilled rotors shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: Rear brake noise from drilled rotors [Re: fourgearsavoy] #2177208
10/17/16 08:36 PM
10/17/16 08:36 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
What KIND of noise? devil
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Rear brake noise from drilled rotors [Re: amxautox] #2177395
10/18/16 12:22 AM
10/18/16 12:22 AM
Rittman Ohio
Rittman Ohio
Almost kind of a whirring wooshing noise when I apply the brakes hard or easy. I can tell by the noise the pads are just starting to make contact with the rotors. My exhaust is very loud and I can still hear it over the stroker with 3" 2 chamber 40 series Flow Master mufflers. Wife and I went for a 40 mile cruise last Saturday and she asked me what that zzrrr zrrrr zzzrrr noise was and thats how she described it laugh2 She said she could almost hear the holes in the rotors going past the pads.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Rear brake noise from drilled rotors [Re: fourgearsavoy] #2177399
10/18/16 12:27 AM
10/18/16 12:27 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
That happens when solid rotor are drilled. Solid rotors should be slotted, only.
Re: Rear brake noise from drilled rotors [Re: fourgearsavoy] #2177416
10/18/16 12:48 AM
10/18/16 12:48 AM
amxautox Offline
amxautox  Offline
Solid rotors have no place for the air in the holes to go. So the air is trying to push the pads away from the rotor. Thus the noise. Vented rotors let the air go thru the holes, and thru the middle of the rotor, then out the outside diameter. No pushing out of the pads.
Tom
author unknown
Re: Rear brake noise from drilled rotors [Re: DoctorDiff] #2177419
10/18/16 12:51 AM
10/18/16 12:51 AM
Rittman Ohio
Rittman Ohio
Yeah It sure is annoying at every stop so I'm stopping at Summit and picking up a set of solid rotors and bolting them on and re-safety wiring them AGAIN mad
All in all though going from 4 wheel 10.5 drums to 4 wheel discs is amazing effortless stopping.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Rear brake noise from drilled rotors [Re: fourgearsavoy] #2199817
11/21/16 05:26 AM
11/21/16 05:26 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Did you try swapping the rotors side-to-side to see if changing the drilled pattern / rotation helps with the noise?
Re: Rear brake noise from drilled rotors [Re: 451Mopar] #2200353
11/22/16 01:21 AM
11/22/16 01:21 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I suspect they are marked with the intended direction. work
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Rear brake noise from drilled rotors [Re: fourgearsavoy] #2201356
11/23/16 06:39 PM
11/23/16 06:39 PM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
It's common for drilled rotors to make a moaning kind of sound.
