Stock Mufflers #2176951
10/17/16 03:15 PM
10/17/16 03:15 PM
Elizabethtown, KY
6T9Hemi Offline OP
6T9Hemi  Offline OP
Elizabethtown, KY
What were used on 69 340's in 69 darts for mufflers? What is the closest replacement you can get?
1969 340 4 Speed Swinger R4,
black vinyl, white butt stripe, 3:91
Re: Stock Mufflers [Re: 6T9Hemi] #2176967
10/17/16 03:28 PM
10/17/16 03:28 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Check with Accurate Ltd.
Re: Stock Mufflers [Re: 6T9Hemi] #2177132
10/17/16 07:11 PM
10/17/16 07:11 PM
Chicago
PurpleBeeper Offline
Chicago
or your local autoparts store that carries Walker
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Stock Mufflers [Re: 6T9Hemi] #2177386
10/18/16 12:06 AM
10/18/16 12:06 AM
New York
rarefish Offline
rarefish  Offline
New York
I bought theses muffles for my 69 Dart GTS 340 from Summit earlier this summer. I too was looking for a aftermarket muffler that was close to the original factory mufflers. So far, I have not installed them as the car is still apart, so I can't report on the fit or their sound.
https://www.summitracing.com/parts/sum-631122-xl/overview/
Re: Stock Mufflers [Re: rarefish] #2177555
10/18/16 10:56 AM
10/18/16 10:56 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
2.25 in and out ... NOT stock on a 69 340 equipped mopar.
I assume he is looking for actual FACTORY replacement , Accurate LTD or Gardner will be the only place that has them.
Here is the muffler you are looking for , you may actually want the ACM-18 though , 1 7/8 outlet like stock ... even the 383 and 440 equipped A bodies used that muffler because they used 340 tailpipes .
http://accurateltd.com/A-Body-Factory-Replacement-Muffler_p_198.html
Re: Stock Mufflers [Re: JohnRR] #2178121
10/18/16 09:59 PM
10/18/16 09:59 PM
New York
rarefish Offline
rarefish  Offline
New York
If it's not 2.25" in and out then what size was it on a stock 69 340 muffler? I talked to the people at Accurate and that's what I was lead to believe. The head pipes are 2.25" and I was told that the tail pipes are 2.25" and then reduce down to 2" along side of the gas tank for the factory 1-7/8" tips. Just when I thought I had this all figured out, I'm now learning something different.
Re: Stock Mufflers [Re: rarefish] #2178444
10/19/16 10:28 AM
10/19/16 10:28 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
smile
Re: Stock Mufflers [Re: rarefish] #2178455
10/19/16 10:38 AM
10/19/16 10:38 AM
Roseburg, Oregon
Tom Swope Offline
Tom Swope  Offline
Roseburg, Oregon
Maybe this will clarify a few things. In 1967 and 1968 , 383 equipped a body cars
had 2" I.D. inlet and 2" I.D. outlet mufflers. On 1968 models when exhaust tips were first available , the two piece welded tailpipes reduced to 1-7/8" I.D. at the rear to accept the exhaust tips. In 1969 this changed for 383 , 340 and M code 440 models to 2-1/4" I.D. inlet and outlet mufflers. The 1969 welded two piece tailpipes were 2-1/4" O.D. at the front downsizing to 1-7/8" I.D. at the rear for the exhaust tips. Assembly line mufflers were welded directly to the headpipes for all models. To replace the muffler , the original muffler was sawed off of the headpipe and the replacement muffler clamped into place.
Re: Stock Mufflers [Re: 6T9Hemi] #2178485
10/19/16 11:47 AM
10/19/16 11:47 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Tom do you have a photo of an original 2 piece tailpipe ?
Re: Stock Mufflers [Re: JohnRR] #2178653
10/19/16 04:13 PM
10/19/16 04:13 PM
Roseburg, Oregon
Tom Swope Offline
Tom Swope  Offline
Roseburg, Oregon
John , Here is one we removed from a 69 340 Barracuda that had the original assembly line exhaust.
Re: Stock Mufflers [Re: 6T9Hemi] #2178690
10/19/16 06:07 PM
10/19/16 06:07 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Thanks , that is very interesting , so the pipes I have are not factory then ...
Re: Stock Mufflers [Re: 6T9Hemi] #2178761
10/19/16 08:51 PM
10/19/16 08:51 PM
New York
rarefish Offline
rarefish  Offline
New York
Tom, Thanks for the tail pipe photo and also I appreciate you clarifying this issue. I have spent a lot of time trying to understand the factory exhaust mysteries for my 69 Dart.
Re: Stock Mufflers [Re: PurpleBeeper] #2180045
10/21/16 11:59 PM
10/21/16 11:59 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
No Walker or AP exhaust for 340 a bodies is available . Been through that futile search.
